Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 12-01-2015, 07:46 PM   #1
2010 25' FB International
Lake Arrowhead , California
Freshwater Tank Leak
I have a 2010 International 25fb. I have a slow leak from my freshwater tank that has been causing it to lose down to about 3/8 capacity within 72 hours or so. When we get home, I'll have it fixed.
The question- is tank replacement a proprietary thing with Airstream or can I take it to a non AS reputable service place? Our closest AS dealer would be 3 hours away.
Thanks folks!
Blueliner is offline   Reply With Quote
Old 12-01-2015, 08:25 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm not 100% sure but I believe you probably want an Airstream team on it. I had to have my FW tank replaced (under warranty) and they had to peel away the belly pan.
Old 12-01-2015, 08:31 PM   #3
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Here's a couple of threads that give background and detail on a 2010 28 footer with a leaking freshwater tank that was replaced. They should give you a decent concept of the work required. I suspect that you want an Airstream shop to do the work because it would be best for the shop to have familiarity with design, layout, and piping.
Another option is to do it yourself if you are into doing such work yourself. It is not a Sunday afternoon project.
http://www.airforums.com/forums/f443...ud-113561.html
http://www.airforums.com/forums/f443...ng-114716.html
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 12-01-2015, 08:42 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The water tanks themselves are not Airstream proprietary and anyone can buy them from a third party supplier. However, working on an Airstream is different than most other RV's (especially when body work is needed as will be the case to drop the belly pan to access the tanks) so you don't want to entrust this work to just anyone. I would rely on either an Airstream dealer or one of the many excellent independent shops around the country that specialize in Airstream work. Whatever you do, don't just go to Camping World or your cousin Vinnie who only has experience working on his Jayco toy-hauler.
Bob Martel
WBCCI# 5766
Freshwater Tank Leak TinTin Waste Systems, Tanks & Totes 10 05-09-2015 07:12 PM
'92 Excella freshwater tank leak msimon Fresh Water Systems 0 09-19-2013 12:23 PM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
Overflow hose in freshwater tank is loose. TBKP's Overlander Fresh Water Systems 1 08-03-2003 08:46 PM
