Old 02-04-2019, 09:59 AM   #1
2018 25' Flying Cloud
Smyrna , Georgia
Fresh water tank fills when connected to city water
Just started having issue with 2018 25 ft Flying Cloud fresh water tank filling when I am connected to city water. Any suggestions to repair this and avoid a trip to the dealer?
DKGA is offline   Reply With Quote
Old 02-04-2019, 10:38 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There is a check valve that is incorporated in the water pump. Sometimes the valve will fail to close because a small object in the water. Run some water through the pump several times and that might clear it out. If that does not work, the pump may need to be replaced.
This is a very common problem.
Richard
Old 02-04-2019, 10:48 AM   #3
Long Island , New York
. . . and lots of earlier threads/posts available for the reading:
"pump check valve bad tank filling" -- https://www.google.com/search?q=pump...com&gws_rd=ssl
Specific sub-forum to check FYI: http://www.airforums.com/forums/f445/
Good luck,
Peter
Old 02-04-2019, 10:55 PM   #4
2018 28' Flying Cloud
Fairfield , California
Had same with our 2018. As stated above, turned off city water, ran on pump for a couple of days to pull down tank level. It's been fine ever since.
StuartsDad is offline   Reply With Quote
Old 02-05-2019, 11:27 AM   #5
2017 27' International
Box Elder , South Dakota
Happens occasionally. Just 'fixed' mine by running it dry with the pump.
alphamale49 is offline   Reply With Quote
Old 02-05-2019, 01:05 PM   #6
2015 25' Flying Cloud
Tigard , Oregon
Steve D.
An inexpensive fix if you donít want to replace the pump is install an in-line check valve. Available @ any plumbing supply.
hallbergstev is offline   Reply With Quote
Old 02-05-2019, 02:05 PM   #7
2007 22' International CCD
Check the pump inlet for a strainer. Sometimes on shiny new Airstreams a bit of shredded plastic from tank fittings installation gets into the water system. Clean the strainer thoroughly and be sure all the parts, including the gasket or O-ring are in the right place and tightened, otherwise you may have trouble getting the pump to prime.
Another tip: ALWAYS fill the water tank using an in-line filter with the hose. This helps keep grit and the like out of the tank. It does not take a very big foreign particle to make the pump leak backwards into the fresh tank while on city water.
As noted, disconnecting city water and running the pump on a full fresh water tank will usually clear the problem after a few pump on/off cycles. It's not an unusual problem...just irritating when your tank overflows water down the side of the trailer out of the tank fill door...
rmkrum is online now   Reply With Quote
Freshwater tank filled up while connected to city water Native143 Fresh Water Systems 16 07-01-2018 04:15 PM
City Water connected but still drawing from onboard fresh water tank holmesaz Fresh Water Systems 8 06-17-2016 08:44 AM
My grey water tank fills when I turn on city water m.hony Plumbing - Systems & Fixtures 36 10-25-2012 09:25 AM
Fresh Water Tank Fills Unexpectedly Jack46 Plumbing - Systems & Fixtures 11 08-11-2012 06:59 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 02:23 PM
