Old 07-16-2015, 05:37 PM   #1
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
Smile Fresh water tank drain valve
The fresh water tank drain valve on my 1998 Excella is located behind the front curbside wheel and is a little unhandy to operate, especially when the valve handle gets tight. Today I raised the front end of the trailer to a point where I could have easier access to the valve handle. (be certain to block the trailer wheels to prevent rolling!) I then laid on the ground and using a small diameter piece of tubing, reached in and placed the tubing over the plastic handle and carefully rotated the handle toward the front of the trailer, to close the valve. I then squirted a small amount of canola oil cooking spray up into the drain nozzle and rotated the handle a couple of times with the tube. Voila! Opens and closes with my hand very nicely. I'm anxious to see how long this will take care of the problem.
coloradopete is offline   Reply With Quote
Old 07-16-2015, 05:48 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My fix for a poor design. Provides leverage without tearing the handle off.
MICHAEL
Fresh water tank drain valve replacement lboyd Plumbing - Systems & Fixtures 21 01-10-2015 06:04 PM
Can't locate fresh water tank drain valve - 1974 27' Overlander International Razorhog Fresh Water Systems 11 04-22-2014 09:14 PM
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
