Old 02-04-2016, 09:52 AM   #1
2004 28' International CCD
Cocoa , Florida
Fresh water drain... Uh ohhh!!
Hello fellow streamers!!
I think I made a boo boo. My fresh water valve was broken and when I got it out, this is what I found. There is a tube inside of what looks like a protective "box" that covers both fresh and black water tanks. There is no slack in the tube, so I can't pull it out in order to hold it so I can get a grip on it and replace the valve. The valve is "barbed" and requires some amount of pressure to install. I have a feeling I'm going to end up dropping this "box" in order to get to the tube, unless someone has any ideas on a easier way..
I hope you all have a FANTASTIC weekend!!
Bhkh226 is offline   Reply With Quote
Old 02-04-2016, 10:00 AM   #2
1986 31' Sovereign
Miami , Florida
Well, the other end of that tube attaches to the fresh water tank. I can access mine under the floor of my closet. Obviously, yours may be different but I would bet that there is some access to that end of the tank from inside your rig. Usually, the water pump is in the same spot and, on mine, so are the tank sensors.
You may have to poke around a bit, maybe even remove a panel or two but you should be able to find it.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 02-04-2016, 10:02 AM   #3
dznf0g's Avatar
Oswego , Illinois
Ditto what Mike said....
-Rich-
Old 02-04-2016, 10:05 AM   #4
Captain Hank's Avatar
2007 27' Safari FB SE
Summerville , South Carolina
Look under the trailer to see if there is an access cover to connect the new valve. If not you will have to cut an access hole and cover it with some sheet metal. You may be able to work it form the inside if there is an access from the inside.
Captain Hank is offline   Reply With Quote
Old 02-04-2016, 10:49 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I know mine will probably break soon. I have no access from above so I'll have to take the cutting wheel to the plastic water tank cover.
I suppose if just the handle breaks but its not leaking a pair of pliers should be able to turn it on/off. Everything in my AS that requires maintenance requires major work to access.
Kelvin
Old 02-04-2016, 10:53 AM   #6
dznf0g's Avatar
Oswego , Illinois
I bought one of the aluminum replacement valves and keep it in my "road parts bag", but since lubing the plastic one with food grade silicone, it works smoothly and probably won't break. At least for a long time.
-Rich-
Old 02-04-2016, 11:06 AM   #7
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
How 'bout a quick course on how you lube it?
The Ice Man is offline   Reply With Quote
Old 02-04-2016, 11:08 AM   #8
dznf0g's Avatar
Oswego , Illinois
I just hit the seam between the body of the spigot and the "turny" part (technical term), worked it back and forth and repeated several times. That was about 5 years ago. Still works smoothly.
-Rich-
Old 02-04-2016, 11:28 AM   #9
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
...but since lubing the plastic one with food grade silicone, it works smothly...
Food grade silicone lube - can you recommend one? Where to purchase?
Greg
greghoro is offline   Reply With Quote
Old 02-04-2016, 11:31 AM   #10
dznf0g's Avatar
Oswego , Illinois
https://www.waresdirect.com/products...Jt8aAqvB8P8HAQ
This is just the first one I came across. Google for more...and I bet it is available locally.
-Rich-
Old 02-04-2016, 11:32 AM   #11
jackson center , Ohio
Schu is offline   Reply With Quote
Old 02-04-2016, 11:53 AM   #12
Rich,
Do you have link for the aluminum valve?
Old 02-04-2016, 11:54 AM   #13
dznf0g's Avatar
Oswego , Illinois
Last time I looked, they were out of stock...let me check.
-Rich-
Old 02-04-2016, 11:56 AM   #14
dznf0g's Avatar
Oswego , Illinois
http://www.ebay.com/itm/RV-FRESH-WAT...0dofNjWCDNPYHw
BOOM, here they are!
-Rich-
Uh OHHH the fridge isn't getting cold arcamedies Refrigerators 9 06-29-2010 07:35 AM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 12 10-07-2009 06:20 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
