Old 01-16-2015, 11:52 AM   #1
1959 18' "Footer"
Newton Abbot , Devon
Frame and belly junction detailing - advice sought.
How do you achieve a niece detailing in the junction/joint where the frame protrudes from the underbelly(rear and front on a late 50's AS)? If anyone has links to detailed restoration photos it would be much appreciated!
Cheers, 1959 18' Globester...
1947liner is offline   Reply With Quote
Old 01-16-2015, 09:18 PM   #2
2009 23' FB Flying Cloud
1959 24' Tradewind
1951 21' Flying Cloud
Northeast , Iowa
Good evening,
Interesting that we are just now installing a new belly pan on a 1959 Tradewind. We are doing a complete shell off restoration and have the facilities to lift and rotate the frame so I have the luxury of working with the frame upside down which makes everything a lot easier. We have found that it is really not too difficult to get the belly pan at the frame ends to come out looking good.
I gather that you do not have a belly pan to use as a pattern?
Here are four pictures of the detail on the rear and the front of the bottom of the trailer at the frame ends. I also took a picture of the old belly pan laid flat on the floor showing the rear detail. Notice how the V is cut. It is not quite as you would picture it so if you have some scrap metal (preferably thin and easy to bend) I would recommend that you practice first.
The last picture is of the frame with insulation but no sheet metal. It is taken from the front of the trailer (again the frame is upside down). You can see how we heavily modified the frame and added a spare tire carrier (and stainless holding tanks). The spare tire area will not have sheet metal over it, so it was easier to make the front belly pan out of multiple separate sheets that we will rivet together instead of one sheet. This is why the front detail does not look the same as the rear.
One other detail that is different on this trailer. I was able to get the belly pan aluminum in 5 X 10 foot sheets but only in .045. It is 5052 H32 but thicker (normal belly pan aluminum is .025 or .032). It is much more difficult to work with but since the frame is upside down, not too bad. The advantage is it lays flat very nicely and should wear very well.
These pictures are probably confusing, but hopefully you get the idea.
Ed
Name:	Ed Iphone 001_1.JPG
ID:	230538   Click image for larger version
Name:	Ed Iphone 013_1.JPG
Name:	Ed Iphone 005_1.JPG
ID:	230540   Click image for larger version
epperp is offline   Reply With Quote
Old 01-18-2015, 08:18 AM   #3
cdmagda's Avatar
Images: 51
You will be hard pressed to make the belly pan terminate right where it needs to. Typically, a gap is present when installed. I remedied this by fabricating some patches (matching) for each side of the protruding frame as pictured, on both the front and back of the trailer, eight in total. The patch here goes under the banana wrap.
Name:	ImageUploadedByAirstream Forums1421594240.779818.jpg
cdmagda is offline   Reply With Quote
Old 01-19-2015, 02:14 AM   #4
1959 18' "Footer"
Thank you both kindly for the pics and detailed reply which have been very useful indeed! Even if the 'cut' is spot on, the extra 'patches' will add support(probably not needed on your ali. grades! ), minimise visible sealant and a nice detail I think.
Thanks again, Per
Old 01-19-2015, 06:41 AM   #5
cdmagda's Avatar
Images: 51
More pics...before sealant.Click image for larger version
Name:	ImageUploadedByAirstream Forums1421674641.435037.jpg
ID:	230711Click image for larger version
Name:	ImageUploadedByAirstream Forums1421674792.333988.jpg
Detailing polish poly glow wax Victor peel Airstream Classifieds 0 02-18-2014 07:55 PM
Detailing wood work on a 67 International Silverwanabe Cabinets, Counter Tops & Furnishings 14 01-31-2008 05:10 PM
Airstream and Aircraft Detailing in Texas jimmy Commercial Listings 0 08-03-2003 02:24 PM
Detailing the windows Charcigar Windows & Screens 5 06-15-2002 07:40 PM
