Old 04-13-2014, 02:44 PM   #1
2013 Int. Sig 23D
Rrroberts40's Avatar
2013 23' International
Des Moines , Washington
Found a part in Refer chamber
Hello, looking for any ideas where this part belongs. I found this in the outer refer area behind the refer. I have a 2013 Int Sig. 23D...it was laying on the bottom nest to the pilot light and vent pipe unattached to anything. The length is about 1.5 inches...what do you think it is?
Rrroberts40 is offline   Reply With Quote
Old 04-13-2014, 02:51 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Can you see an empty screw hole near the gas burner where this bit has fallen off? I am just guessing but I think it may be a gizmo that prevents the burner flame from being extinguished by drafts when you are underway. Jim
Jim Flower is offline   Reply With Quote
Old 04-13-2014, 02:54 PM   #3
2013 Int. Sig 23D
That thought crossed my mind to although I do not see any mark around the screw hole in this part that indicated it was ever mounted...I will go out now and take another look see...thanks
Old 04-13-2014, 03:08 PM   #4
2013 Int. Sig 23D
Just took another look and do not see anyplace it could have come from...all things seem to be working fine so am not sure if it didn't just get dropped in by mistake...
Old 04-13-2014, 03:16 PM   #5
tinbender's Avatar
2001 16' Bambi
Piedmont Region , North Carolina
Open the top refer outside vent and look at the top of the burner stack. That part slides down into that tube covering the "wire handle" that is attached to the baffle. Does not screw down, the tabs on the part slide down over the wire handle into the tube, covering the wire.
tinbender is offline   Reply With Quote
Old 04-13-2014, 03:22 PM   #6
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
If you google Dometic refrigerator and then find some repair videos on utube, you may see the part. It could also just be a bit left over from construction. I am forever finding bits that have rolled out from someplace during my travels and I put them in a little container waiting for the day when I discover what they are for. Jim
Old 04-13-2014, 03:39 PM   #7
tinbender's Avatar
2001 16' Bambi
Got you a photo
Her ya go, went outside and took this.
Old 04-13-2014, 05:38 PM   #8
2013 Int. Sig 23D
You folks are the bomb...never would have guessed it went there but I did look closely at the area and until the pic I could not have guessed...2 secs and it is back in it's proper home...thanks so much!!
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Replacement Sink / Shower Faucet part - No clue on part # natmoody71 Sinks, Showers & Toilets 0 03-07-2010 10:08 AM
Refer Blues Part II/ 71 Tradewind Lumatic Refrigerators 0 07-15-2007 06:12 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
