Old 04-02-2013, 08:21 AM   #1
1976 25' Tradewind
Chandler , Arizona
Foam insulation
I have a 1976 Tradewinds and live in the Phoenix Az area. Needless to say, it gets HOT here. I was wondering if anyone has added non expanding foam to the cavity between the inner and outer skin of an Airstream trailer. So far, we have had mid to high 80's for daytime highs. Even when it is in the 70's, it gets very warm inside, the inside ceiling panels are very warm to touch. I was considering drilling about a 3/8 in. hole in the center of an inside ceiling section, (between the braces) ,filling that section with non expanding foam and then putting a white plastic plug in the hole. If anyone out there has tried this or has experience with it, let me know. Thanks.
Happy guy is offline   Reply With Quote
Old 04-03-2013, 05:10 PM   #2
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
A few yrs back on my 1st restore I had the same question. My '64 Airstream was shell off & interior skins out. I had so many warnings against foam I reinsulated with fiberglass. Last summer I started a '64 Avion T28, same DBL wall Alum construction as Airstream. Couldn't believe it, is insulated with spray foam......The few interior panels I've removed show perfect insulation. No crumbling, cracks, no D**N rodent nest or pathways,and no foul smell. The two 1964 coaches sit side by side. The Avion is way quieter in a rain storm, and cooler in the blazing sun. I have a '62 AS Ambassador I'm starting next, barring new insight I'm going with foam. There is a major difference between Avion & Airstream. Avion has a rigid frame, AS does flex. We'll see. In your case it would seem the insulation now between the skins would block the foam from filling the space well. Good luck.
putback is offline   Reply With Quote
Old 04-07-2013, 08:58 AM   #3
1976 25' Tradewind
Chandler , Arizona
Did you do the spray foam insulation from 12-16 oz. cans, go the professional route, or somewhere in between?
Old 04-07-2013, 09:36 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I would bet you have fiberglass insulation already in the ceiling and walls of your trailer, unless you've removed it in the past. I would think you'd have to remove your inner skins in order to insulate with spray foam.
Kay
Old 04-07-2013, 09:43 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Kay
This ^^^ there is already fiberglass batt insulation in there. If you put spray foam in without removing them you are asking for a brutal mess. Also you will need to put some sort of thermal break between the skins and the ribs to help minimize the thermal transfer. I think the main reason for not using spray foam in Airstreams is due to the movement, they are very flexible and move about a fair bit when being towed.
Aaron
WBCCI #XXXX AIR #2495
Old 04-07-2013, 10:47 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Here is a couple of things that I know will help:
-awnings all around
-reflective paint on roof
-solar window screens
I have also glued "Reflectix" to the inside of all cabinets and blocks of 2" stryrofoam covered with Reflectix the wardrobe.
I also am going to add reflective window tinting.
I intend to continue this process to the ceilings and walls and cover this with upholstery vinyl, but this will take a while The photo is from a 64 Overlander
My reasoning is if I can cut down on solar and outside temp heat gain and transfer in the nooks and crannies it will help keep cooler in the summer and warmer in the winter. I don't expect spectacular results and you have to weigh the cost of the material and labor vs. comfort and energy savings.
Old 04-07-2013, 12:08 PM   #7
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
this is good to know. i knew avion used spray foam insulation but i had been wondering how it held up over time.
How, btw, is avion non-flexing? Is the frame stronger?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 04-07-2013, 12:18 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
This may or may not be a deciding factor but don't overlook flammablity and off gassing of foams. The Reflectix I mentioned above is non flammable and non off gassing. It has also been used on rebuilds inside the outer skin before fiberglass is added.
Old 04-07-2013, 12:31 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
The Avion uses a stronger frame. The frame supports the shell in an Airstream the construction is semi-monocoque and the shell actually helps support the frame. An Airstream bare frame is very flexible, the Avion frame is much more rigid.
Aaron
Old 04-08-2013, 08:48 AM   #10
1976 25' Tradewind
Chandler , Arizona
Thanks to everyone who replied. With the info that I've received, I'm going to give op on this idea. Once again, thanks to all who took the time to respond, many heads are better than one.
