Old 04-12-2015, 09:51 PM   #1
1980 24' Caravelle
windsor heights , Iowa
floor rot repair
What is the best product to apply to a rotted floor. I am in the process of drying it first. Thank you much, Sallie.
walle is offline   Reply With Quote
Old 04-12-2015, 10:00 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Sallie
Can you show us some pictures? The best way to fix it is to replace the rotted wood but if it's not too big an area you maybe able to treat it or patch it.
Pictures would help.
Mike
desertair27 is offline   Reply With Quote
Old 04-12-2015, 10:02 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
You may be looking for something like this
Wood preservation, rot repair, and restoration using epoxy resin on boats, homes and log homes.
This only helps solidify what's left, it won't "restore" the wood to it's original condition.
Others will have many different opinions.
DryFly is offline   Reply With Quote
Old 04-13-2015, 03:31 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are several brands of penetrating epoxy resin including Rot Doctor. Don't just use a regular epoxy resin which will sit on top of the wood, get a product which impregnates the wood. You do have to remove the real bad rot before application. The resin will stabilize and strengthen the surrounding wood.
Lumatic is online now   Reply With Quote
Floor rot repair with epoxy A W Warn Repairing/Replacing Floor &/or Frame 36 09-18-2017 06:43 PM
Rear Water Entry and Floor Rot Repair in '68 Overlander Bunkroom Repairing/Replacing Floor &/or Frame 5 11-05-2014 09:29 PM
floor rot repair at Airstream Service Center Alumitater Repairing/Replacing Floor &/or Frame 9 09-12-2013 06:41 PM
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
