Old 03-16-2015, 02:17 PM   #1
2006 28' Safari SE
Eagle River , Alaska
Floor leak ...
The rear right corner floor in the closet of the bedroom of my Airstream 28' Safari becomes wet after a rainstorm. I am soliciting information to see if anyone has experienced this problem. I'm also curious if this is a chronic problem for others, and where you might have found the leak to be coming from. At least it would give me a point to begin to systematically seal specific places. I would be grateful for any advice. Thank you!!
borealis2013 is offline   Reply With Quote
Old 03-16-2015, 02:43 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Leak maybe coming in between the bumper and the rub rail the runs across the top of the bumper. Could also be the seal of the rear storage or leaking where the awning is mounted. Many owners of your vintage have had this issue. Check the other closet and under the bed too. If it's just started maybe the subfloor is still sound. Check the rear window. The miter joints of the window frame will leak too.
Kelvin
Old 03-16-2015, 11:28 PM   #3
2006 28' Safari SE
Thank you, Kelvin!! Your advice is most helpful and gives me several areas to check out and begin waterproofing.
Roy
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Wet floor, finding & stopping leak Joseph O. Smith Repairing/Replacing Floor &/or Frame 4 03-24-2003 10:17 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
