Old 07-29-2012, 02:15 PM   #1
2002 25' Safari
Va. Beach , Virginia
Flat Tire HELP
I'm on the side of the road with a flat (25' Safari). I can't get the lug nuts to loosen, but there is a tiny bit of play both ways...maybe 1/16". If anyone can help please give me a call 757-574-2709.
Thanks!
Mark
Chaffmc is offline   Reply With Quote
Old 07-29-2012, 02:54 PM   #2
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
I don't know what is needed to get the lug nuts loose. But I do understand that it is alright to pull it with three good tires a short distance. Just go slow.
BeachHouse is offline   Reply With Quote
Old 07-29-2012, 03:02 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
That tiny bit of play both ways is not the lug not loosening, but the decorative chrome cover. This cover does not come off, it is pressed onto the actual lug nuts, it is often a bit loose. Someone may have muscled the nuts on there without a torque wrench. You need a longer bar to break them loose.
Many have replaced these original lug nuts with a solid chromed version.
doug k
Old 07-29-2012, 03:30 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Yes, but tire damage is a possibility.
Old 07-29-2012, 08:21 PM   #5
2002 25' Safari
Yeah, my lug wrench is pathetic and I couldn't get enough torque to loosen the nuts. A DOT truck stopped to help out and we got them loose. Got the spare on and all is well. Funny thing is the flat looks fine. I'm going to air it up tomorrow to find the leak but was wondering if I could have side loaded it and broke the seal on the rim? Has anyone heard of this happening?
Mark
Old 07-29-2012, 08:55 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We use our torque wrench to get lug bolts off and on...works far better than a regular lug wrench because you have far better leverage... It's good to check your lug bolts for tightness periodically anyway...Don't leave home without it...
Glad you got it changed and all is well...
TB & Greg and Abbey Schnauzer
#3954
Old 07-29-2012, 09:17 PM   #7
dkottum's Avatar
TB, or anyone, does it hurt the calibration of the torque wrench to use it as a breaker bar? If not that would be great and one less tool to carry around.
doug k
Old 07-29-2012, 09:21 PM   #8
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
I may be wrong, but I seam to recall reading or hearing that you should not use your torque wrench to remove the lug nuts because it can be damaged (thrown out of calibration?). I would like to hear from the pros if this is true or not.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-29-2012, 11:44 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I have not heard that there's an issue with using a torque wrench to loose lug bolts. The calibration of the torque wrench is adjustable ... I don't see the harm of loosening a lug bolt with it if the calibration is reset before using it to torque lug bolts....especially when it's nearly impossible to loosen the lug bolts without it.
#3954
Old 07-29-2012, 11:55 PM   #10
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Adjust your torque wrench to a setting higher, say 100 lbs, than the applied setting, usually 85 lbs. You won't damage your calibration.
SeeMore is offline   Reply With Quote
Old 07-30-2012, 12:03 AM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you can use a torque wrench for removal, but I personally carry a breaker bar for this purpose. Remember to unwind your torque wrench when not being used; Mine stores at the lowest setting, which is 20lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-30-2012, 09:59 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
doug k
Most torque wrenches can be damaged by, well, excessive torque.
The old "beam style" ones get thrown out of calibration.
On the newer "ratchet with a click" style ones the ratchet is the weak point, especially on the cheaply made ones. I've wrecked one just by using it at the high end of its torque range.
Even the really good ratchets aren't as strong as flex heads.
Old 07-30-2012, 11:11 AM   #13
urnmor's Avatar
Berlin , Maryland
By now you may have the lug nuts loose if not you might want to try adding leverage to your lug wrench by adding the brass bar used to help with the sway bars. this just might provide the leverage you need.
I replaced my lug wrench with the old fashion ones that came with the cars way back when. They look like a cross and have four different nut sizes on the end. They provide significantly more leverage then the single bar wrenches.
John
urnmor is offline   Reply With Quote
Old 07-30-2012, 12:03 PM   #14
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
O.k. This is important!!!
For everyone. In a discussion with Kip, our resident Airplane/Airstream metal magician, at the Resto Rally in Albuquerque, overtightened tight lug nuts came up in discussion.
We were amazed at the way our favorite tire shops....and some of us doing our own maintenance....install tires.
Watch 'em. Tire off. Tire installed and placed on Airstream. Air wrench used to tighten all lug nuts. Then (if your lucky) a quick run around with the torque wrench.
WAIT A MINUTE!!!
How are they going to check the torque reliably AFTER putting the nuts on with a powerful air wrench...? If they over tightened the nut you will never know with that torquing....and you may be so overtightened that you will not be able to take the tire off without a breaker bar. The torquing has to begin below the lbs set on the wrench. Make 'em do it right.
