2010 30' Classic
South of the river
Originally Posted by TG Twinkie
80# is sufficient. Don't use the torque wrench. Get a cross wrench or long breaker bar to remove the lug nuts.
In general a tire cross will not work on late model Airstreams because the lug nuts are in small recesses that will not admit the bulky socket used on tire crosses. I carry a breaker bar, short extension, and deep well socket.
I saw the Discount tire shop use a Torque stick type socket. My local shop did not.....now I watch them .
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
So it turns out there is a hole from a nail in my tire which caused the flat. It looks like a simple plug will take care of it but I'm wondering now if there are any issues using plugs on high(er) pressure tires? The tire is a Goodyear with a 65 psi rating and the hole is not on or near the sidewall. I'll check with the manufacturer but thought you all have probably already been down this road a few times and will have a good answer.
Steel belted radials will shear off plugs. To properly repair a puncture, the tire should be patched from the inside. If you have a Discount Tire store nearby, they repair flats for FREE.
