Old 03-03-2015, 11:55 AM   #21
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by chrischarles View Post
Is the flagpole mount that sits below the tire any better than the flagpole that mounts to the hitch? Please help.
I don't have a lot of choice with my Interstate but to use the under-the-tire mount. If you get one, make sure the base is very stiff. I bought two mounts that weren't stiff enough (I have four flags to fly: US, LA, CoE, WBCCI). The wind was from the north; my van was facing west. The flagpole on the north side caught the wind and actually bent the base of the mount so that the flagpole banged against the side of the van.
Fortunately I had the foresight to wrap the flagpole with pipe insulation so there were no dents or scratches on the side of my Interstate. But I immediately ordered a better pair of mounts that won't bend as easily, which I'll try out on my next excursion.
If you can find a mount that attaches to your hitch, or to the front of your propane tank cover, or whatever, you're much better off than with an under-the-tire mount. I've seen trailers at WBCCI events where they flew as many as five flags on poles arranged in a fan shape, all attached to the front of the trailer on a single mount.
Cats and ultraleather Airstream upholstery don't mix!
Old 03-03-2015, 12:01 PM   #22
A review on the webpage indicates the lowest section of that pole is about 4" in diameter, kind of big for any of the portable bases I've seen. I don't know about the OP, but I need telescoping poles with a lower-section diameter less than 2-3/8" in order to fit my portable bases.
Old 03-03-2015, 03:12 PM   #23
z , North Carolina
What a Fiasco
I have a story to tell on getting a mount put on my 28. This really has been a HUGE ordeal. I will post pictures with full explanation just as soon as I can. This has been the most frustrating project, and if I wasn't a veteran, I wouldn't have put so much effort into getting this done RIGHT. Very proud to fly the U.S. flag.
Older rigs are at a true advantage when getting this feat accomplished. Seems everything I did had to be modified one way or the other. I have FINALLY gotten all of the components together to mount my holder. Arrgghhh. More on this tmrw.
FishinHatteras is offline   Reply With Quote
Old 03-03-2015, 03:16 PM   #24
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
4" wont bend!
DuncanK1 is offline   Reply With Quote
Old 03-03-2015, 04:15 PM   #25
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Originally Posted by BoldAdventure View Post
We had a 4 pole mount, made out of aluminum attached to the electric jack. I took it off and promptly threw it in the trash can.
One man's treasure...
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 03-03-2015, 04:23 PM   #26
Originally Posted by DuncanK1 View Post
4" wont bend!
It's not the flagpole that was bending in my case. It was the flat metal plate that goes under the tire. And since the tube attached to the base was only big enough to hold a 2-1/4" diameter pole, there wouldn't have been any way to attach a 4" diameter pole to the base anyway.
Old 03-04-2015, 12:50 AM   #27
z , North Carolina
Geez BoldAdventure
Geez BA, if you don't have anything positive to say, why post?
You threw a $95 or $165 option into the trash can. And your point is?
Not here to stir the pot, but I find your post to be counter productive to the spirit of the board. We are here to help each other, foster new relationships, and insure all of us are able to enjoy the great outdoors TOGETHER. Throwing something into the "trash can" is a negative I could do w/o when visiting here. I don't care what flag you fly, just be proud of WHAT you fly.
Old 04-19-2015, 06:11 PM   #28
2015 25' Flying Cloud
Dallas , Texas
Need a flagpole holder
I want to order a flagpole holder from sandlapper if possible
Doc Holiday is offline   Reply With Quote
Old 04-19-2015, 07:10 PM   #29
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Hey Doc, sending you a PM.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 04-27-2015, 09:26 PM   #30
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
3 pole flag mount
I'm interested in your 3 flag holder/mount. Pic & cost incl shipping to FL, please?
E mail:
do84148@tampabay.rr.com
369goose is offline   Reply With Quote
Old 04-29-2015, 09:12 AM   #31
sandlapper's Avatar
1993 34' Excella
reply coming your way. Thanks
John
Are you kind?
Old 04-29-2015, 03:32 PM   #32
Chilicook's Avatar
Houston , Texas
This 20' telescoping pole is from Camping World. I secure it under the tongue jack. Works great. Stores under the front gaucho sofa.
Chilicook is offline   Reply With Quote
Old 04-29-2015, 03:35 PM   #33
Chilicook's Avatar
Houston , Texas
Flag Pole Photo.
Old 04-29-2015, 04:50 PM   #34
batman's Avatar
1964 22' Safari
modesto , California
Originally Posted by Protagonist View Post
I tried a pair of those flagpoles just last week, except in the 20' length. I was not impressed. The upper clip in each pair tended to slide down. Also, the twist-locks on the sections tended not to stay locked after the wind shifted and wrapped the flag around the pole, so the poles partially collapsed to a shorter length.
I'm presently looking for better telescoping poles that use spring-loaded buttons to lock in the extended position, and with rotating anti-furling rings to attach two flags to. Preferably in a 20' length for use with an "under the tire" base on my Interstate so I can get the lower flag on each pole above the van's roof line. So far I've not had a lot of luck; those features seem to be more common on poles for permanent mounting at home than on portable poles for RV use.
Protagonist, take a look at these guys. They have a very nice 22' fiberglass pole that has locking pins to prevent collapsing, breaks down to 48" 4lbs and a carrying case for $54.95.
We have ordered from them and like the quality of there flags.
-Dennis
batman is offline   Reply With Quote
Old 04-29-2015, 07:02 PM   #35
2020 Classic 33 on order
Box Elder , South Dakota
Batman no link in your post.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 04-29-2015, 07:52 PM   #36
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Like Doc and 369Goose, I'd like pics and info. I'm interested in the 3 holer, maybe a 5 holer but only use 3, but not good enough on the Forums to find any of your Pics.
The Ice Man is offline   Reply With Quote
Old 04-29-2015, 08:11 PM   #37
TCwheels's Avatar
I definitely endorse Sandlapper's flag poll holder. I have the three hole version and it's a high quality, well-designed product. I don't have close up photos to post, but I will take some and post them when I get my trailer back from JC - I'm going to add an LED light and switch so I can light the American flag after dark.
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
Old 04-30-2015, 01:21 AM   #38
batman's Avatar
1964 22' Safari
LOL, sorry about that.
Poles and Holders :: Poles :: PNH-22-Deluxe (**NEW** and MOST Popular!) Flag Pole - Your place for Flag Poles, Flags and Mountings
They have a decent selection of flags, poles, mounts and accessories.
-Dennis
Old 09-26-2016, 02:11 PM   #39
WBCCI 23945 "Blue Moon"
1993 29' Excella
Hillsboro , Texas
Finishing the Flag Pole for Display
Originally Posted by Urbanologist View Post
Blue Hawk painting poles work great! Six foot - Twelve foot style cost $14 at Lowe's.
Our holder is on its way, poles purchased, flags purchased, anxious to fly our colors.
Questions for those who use the Great Hawk poles. Anyone find something particularly befitting for a pole cap? Welcome any ideas. Also, any tips on mounting the flag. We purchased the swivel mounts, but the base has to be cinched down to the pole and I am just not sure how much cinching it will take before structure is breached.
Scott
chili4u2 is offline   Reply With Quote
Old 09-26-2016, 03:39 PM   #40
WaLee's Avatar
Nevada City , California
I have sandlappers pole mount. Very nice item. I use the painters poles. I got some wooden finials from "The Flag Store" in Sparks NV. I also use plastic swivel clips to hold the flags. A little wrap of duck tape makes the finial fit snugly. eventflags.com
WaLee is offline   Reply With Quote
Correcting Skin and Structural Damage Related to Leaks Steve Bryant Ribs, Skins & Rivets 16 05-22-2012 06:24 PM
Springstream 2012 in N.Georgia ALANSD Forum Rallies & Meet Ups 174 05-09-2012 04:33 PM
Mobile Hair Salon in Winter climate???? Avicia Winter Living 20 03-11-2012 02:58 PM
Gambrill State Park in Maryland Mike Steele On The Road... 3 03-04-2012 03:05 PM
Shower backup in my Mini ffrick All Argosy Trailers 6 03-04-2012 01:40 PM
