Old 02-14-2016, 08:54 AM   #15
2016 27' International
Columbia , South Carolina
We had a similar problem years ago with one of our former units, and it turned out the regular was mounted crooked. Repair man came out, poped the bottom screw out, leveled it up, put the screw back in, and we were back in bussiness.
dazwelding is offline   Reply With Quote
Old 02-14-2016, 10:23 AM   #16
Long Island , New York
Originally Posted by jeffryorange View Post
Thanks to all you ASers out there who responded to our problem of no propane on our first trip out. After trying many of your suggestions to no avail, we decided to go back to the AS dealer (1.5 hours out of our way). They ended up installing a new regulator so turns out nothing we could have done. However, if this were to happen again does anyone have a short-term "gerry-rig" solution?Thanks
There is no shortcut to bypass a bad regulator IMO. I thought the dealer sent you off with all systems working at the get go? A small plug in electric heater or two are good to have on hand for propane emergencies, but obviously you need electric.
Glad you are on the road again!
Peter
Old 02-14-2016, 10:59 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You can buy a cheap regulator at WalMart or Home Depot to get yourself out of a tight spot should this happen again.
Brevi tempore!
Old 02-14-2016, 09:49 PM   #18
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Suggest that you have a propane pressure gauge (manometer) installed. Mine is installed using a "T" in the gas line to the refrigerator. That way you can tell if the regulator needs adjusting.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
First AS - First Trip PharmGeek On The Road... 70 12-05-2013 03:25 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
First Trailer, First Trip Tin Diesel On The Road... 15 02-01-2006 12:23 AM
First Big Trip, First Time Float Tubers :eek: CaliforniaStreamin On The Road... 14 08-11-2005 02:18 AM
