Old 06-10-2012, 05:43 PM   #1
2010 28' International
HiGhlands Ranch , Rockies
First Flat
I have my first flat (after 15K). It is really just a slow leaker attributed to a nail. I did get manage to get home and was wondering the best way to get the tire off and take it to the tire shop. Or should I just take the trailer in and have them patch or replace there?
I saw several recommendations about pulling the trailer up on blocks and then pulling the tire off. I have some leveling blocks that would get both sides up 3 inches of so. Will this work? I also saw that people have suggested jacking the affected side. I don't see a good place to put the jack and I don't think that I have a jack for the trailer.. Was I supposed to get one when I purchased it? I would think that I could use a regular car jack?
Would great appreciate as much guidance as possible.
Coloradoair is offline   Reply With Quote
Old 06-10-2012, 05:49 PM   #2
PLDodd's Avatar
1975 Argosy 26
Portsmouth , Virginia
I think you will find if you either pull up or back up onto the blocks with the good tire only it will sufficiently raise the flat tire/wheel off the ground for removal. Remember to break the lug nuts loose first! If you should have to disconnect from tow vehicle, chock up the other side real good. Since it is not on a jack or anything like that that could fall though, you are relatively safe should the camper roll a little. Had it happen to me, didn't need a jack. Good luck
PLDodd is offline   Reply With Quote
Old 06-10-2012, 06:50 PM   #3
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi
Don't put the blocks on both sides of the trailer, Just under the good tire on the same side as the flat.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 06-10-2012, 07:24 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You would not have received a jack with the Airstream. We have used the jack from our truck but after a blowout that we had to change on the roadside (it's a single axle) we got a small floor jack to carry.
With a multi-axled trailer the best way is to first loosen the lugs on the bad tire (to loosen them) then drive up onto a wedge or interlocking blocks to get the bad tire off the ground far enough to get it off the wheel and replace with a good tire... Be sure to chock the good side of the trailer so it can't go forward or backwards...so it won't roll front or back...
We lived through a complete blow out and changing the tire on the road, and you, too, shall live through this... Take it nice and easy and you'll get it done...
TB & Greg and Abbey Schnauzer
#3954
Old 06-10-2012, 07:59 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I bought a "Trailer Aid Plus" and it sure made it easy and simple to change tires. The tire shops were impressed too.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-10-2012, 08:02 PM   #6
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I carry one of these:
Trailer-Aid PLUS -- Yellow - Trailer-Aid Store
For future tire problems:
Limping home on a leaking tire is not at all a good idea, especially with an Airstream. The aluminum is vey fragile compared to fiberglass and other similiar trailer construction materials. A tire that starts to disintergrate can do many dollars of damage in an instant.
I learned this the hard way with my 21' Bigfoot. The nail causing the leak came out and the quickly ensuing blowout damaged some rubber pieces of the wheel well and put a lot of black marks on white fiberglass. I am sure if the same happened in our Airstream, I would be looking at a multi thousand dollar panel replacement.
Ken
Old 06-10-2012, 08:48 PM   #7
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I went through this just today. My tire monitor started beeping and I was able to get off the interstate onto a good, flat, paved surface with 48 pounds still in the tire.
By the time I was arranging my blocks to raise the trailer, a nice, young man stopped and helped me take off the tire with the nail and mount my spare. He told me of a tire shop that was open today (Sunday), just a mile away. I had them throw away the old tire since I intended to replace it anyway after this trip. I had an unmounted new tire laying in the bed of my truck and that went on the rim. I came the rest of the way home (125 miles) with the spare on and had the extra confidence of knowing that I still had a spare if needed.
I think from now on, on any really long trip there will be a second spare carried in the bed of the truck.
John W. Irwin
WBCCI #9632
Old 06-10-2012, 09:37 PM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I'm looking at getting a tire monitor. What brand did you get? and do you like it?
That thing saved you from shredding a tire. I like the idea.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-10-2012, 09:50 PM   #9
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
This is one reason we went tandom.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-10-2012, 09:54 PM   #10
Ag&Au's Avatar
Dan
Tandem is not going to prevent the damage caused by the flying and whipping fragments of a blown out tire.
Ken
Old 06-10-2012, 10:03 PM   #11
danlehosky's Avatar
No Ken, but it will keep you from swerving all over the road on your brake drum.
TAC
Hope is not a plan.
Old 06-10-2012, 11:03 PM   #12
Pahaska's Avatar
Hays County , Texas
I have the PressurePro. It has saved me damage 4 times over the about 5 years I have owned it.
When at a red light, when on a straight stretch of road, and whenever starting up after a rest stop, I click through the tires, looking for any anomalies such as low or unusually high pressure in a tire.
John W. Irwin
WBCCI #9632
Old 06-10-2012, 11:09 PM   #13
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
There are several brands available, but this is what I use. It has been very dependable for about 5 years now, and alerted me when I had a sudden valve stem failure a couple of years ago. I'm convinced it paid for itself that night. The tire dropped to 27 PSI, and if I continued riding on it, there would have been a blowout which would have very likely caused damage on a single axle trailer.
PressurePro Tire Pressure Monitoring System TPMS Pressure Pro
If it were to break down today, I'd replace it without hesitation. This time, I would likely get one that reads tire pressure, temperature, and has tire sensors that the user can change the batteries. My current one only reads tire pressure, and when the sensor batteries get weak, you have to exchange them for new ones at considerable cost.
Good luck with your selection.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 06-11-2012, 09:29 AM   #14
Ag&Au's Avatar
Jason
After some research, I bought and am pleased with the HawksHead Pressure track HD. HawksHead Pressure Track HD
Here is one thread of several on TPMSs:
http://www.airforums.com/forums/f438...pms-70821.html
Ken
