Old 09-14-2019, 01:07 PM   #1
2018 30' Classic
Mountain View , California
Firefly Issue
Our 2018 Classic is controlled by the Firefly software. In the past two years we have had to replace 3 converters, 2 inverters and both A/C units twice. We are informed that the software was the root cause and that it continues to have a “bug” in it and both the factory and the software company are working on a solution for us.
We are also told that our unit is unique in this experience. I am interested to know if your own experience has been without a similar issue in regards to the Firefly software.
The warranty runs out this month on our unit and the factory has been good for the multiple replacements, even extending the warranty for a year but not on “vendor supplied “ items like the a/c units. Thoughts please.
JFRINALDI is offline   Reply With Quote
Old 09-14-2019, 02:47 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We have an 18 classic. No issues like yours. We did have our firefly upgraded when we visited JC. I believe it’s version 3.8
Can you confirm that you have the latest version?
BigSxyWhtGuy is offline   Reply With Quote
Old 09-14-2019, 02:48 PM   #3
2018 30' Classic
Old 09-15-2019, 08:54 AM   #4
2018 30' Classic
Latest version
Thanks for your response. We have had the latest update installed at the time our first set of a/c’s went out. The software keeps the power going to the coils of the a/c whenever plugged in, even when not in use, thus burning them out.
Old 09-15-2019, 07:29 PM   #5
2018 30' Classic
Sorry to hear. Have you tried reaching out to JC specifically or are you just working with your local dealer?
Old 09-15-2019, 10:05 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Ummmm ..... errrr ......
The converter / charger does not connect to the Firefly in any of the trailers. There is pretty much nothing at all that the firmware in the Firefly can do to kill a converter charger.
The inverter is either on or off. In both the on and the off mode, it self protects. Again, regardless of what the firmware tells it to do, it's very hard to see how there could be a connection.
Indeed you *can* mess up an AC unit by doing odd things to the control signals so that part might actually make sense.
Unit specific software bugs are highly unlikely. Unit specific *hardware* issues are far more likely. Your problem sounds much more like a Firefly hardware issue that any sort of software bug. ( = replacing the hardware is the answer).
Old 09-16-2019, 03:35 PM   #7
2018 30' Classic
Update
Thanks Uncle Bob, always enjoy your responses on the forum. I’ll pass your thoughts on to the Factory and Bay Area Airstream this coming Wednesday when we shall get an update.
Old 09-17-2019, 10:25 AM   #8
Half a Rivet Short
Hi
When I had a replacement / aftermarket converter die, it took the system up to around 21V. Yes that's an odd thing to have happen. Indeed it fried some of the LED lights. If something similar happened with one of your converter failures, it could easily have damaged the Firefly hardware ....
Old 09-17-2019, 03:59 PM   #9
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi JFRINALDI,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can learn more about your situation. We look forward to hearing back from you.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 09-17-2019, 11:51 PM   #10
2018 30' Classic
I have tried multiple times to respond via the Forum. Apologies if there are repeated replies. My Vin# is 540556. Dave at extension 7358 is at the Factory and has been following up at your end with my request to be able to get a new unit because of this multiple problems
Old 09-19-2019, 09:16 AM   #11
Half a Rivet Short
Hi
ummm ... errrr .....
The magic posts asking you to contact the factory are done by an outside contractor. The people doing it have no real idea if you already are in contact with the factory or not. Thus you may get these random requests that pretty much make no sense.
Posting VIN numbers / serial numbers in public is generally not a great idea. It isn't the end of the world, but there are ways people could use that info. They also could walk by your trailer parked in a campsite and get exactly the same info.
Old 09-19-2019, 11:26 PM   #12
2018 30' Classic
Thanks Again Uncle Bob!
Thanks for the reprimand, in my haste to get the message to Airstream I failed to make it a private one. By the way, what kind of surge protector are you using? I found out today that the Surge guard model I have doesn’t protect from low voltage brown outs. There is a more expensive model ($345.00) that does and can even include a remote attachment for the inside of your RV that provides current reading.
Still awaiting a satisfactory solution to my other issues...
Old 09-21-2019, 06:38 AM   #13
Bumpy's Avatar
2003 30' Classic
Edisto Island , South Carolina
You can edit your post, should you feel the need.
Politicians, like diapers, should be changed often, and for the same reason!
Mark Twain
So 'em
Bumpy is offline   Reply With Quote
Old 09-21-2019, 10:15 AM   #14
Half a Rivet Short
........ By the way, what kind of surge protector are you using? I found out today that the Surge guard model I have doesn’t protect from low voltage brown outs. There is a more expensive model ($345.00) that does and can even include a remote attachment for the inside of your RV that provides current reading.
Hi
I started off with an external Progressive 50A EMS. After watching it sit in puddles and rust away, I decided that any benefit from it being at the post was outweighed by the "wet factor". It being a great big lump to muck with when setting up and tearing down also was not ideal.
I swapped it out for an internal and am quite happy with that. It also is a 50A unit from Progressive and has a little display dongle that goes with it. The dongle is taped on the wall above the sink. I can easily see all the status / alarm messages without any messing around.
https://www.progressiveindustries.net/ems-hw50c
2018 interstate TB Firefly a/c issue LewK Sprinter and B-van Forum 56 05-21-2018 08:11 AM
Firefly :: 2016 Airstream International Serenity GandTSayor Airstream Registry Discussions 1 06-12-2016 07:33 PM
Firefly :: 1978 Airstream Excella 500 heather.rauh Airstream Registry Discussions 0 06-10-2013 06:13 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
