Old 11-17-2009, 07:21 AM   #1
funkill's Avatar
reno , NV
Images: 27
Fire extinguisher - Where & How Many
Soooooo, where do you keep your fire extinguisher? I have only one and keep it in my kitchen pantry. On second (or third) thought, I don't think this is an appropriate place. I dislike the look of it hanging on a wall, but.... I even wonder if I should have a couple and place them in differing areas.
Oh, and what type do you carry. I found one RV website that says it should be BC rated. But, in the same article, it mentions that many RV fires are of A type. ???
Thanks for your thoughts,
Laura
funkill is offline   Reply With Quote
Old 11-17-2009, 07:31 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I keep one in the area where I sleep. I also have one in the kitchen in case of a fire in that area.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-17-2009, 07:38 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
One just inside the doorway and onother in the TV.
Ahab is offline   Reply With Quote
Old 11-17-2009, 07:41 AM   #4
1971 29' Ambassador
Leonardtown , Maryland
One in bed room near door and one in kitchen area next to exterior door and both in full view and easy access.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 11-17-2009, 07:54 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
One is mounted on the wall near the floor by the main entry door and the other is in the bedroom on the wall near the floor. I got 2.5# ABC's for mine. Had to go to a regular fire extinguisher service shop for that type. This way I am cover for all types of fires even outside the coach. In addition, the TV also has 10# ABC.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 11-17-2009, 08:13 AM   #6
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
We have the standard one by the entrence door, a second one in the closet next to the bed. I also installed a Fireboy automatic (FE241 chemical) fire extingusher in my refrigerator compartment after having the Dometic recall work done.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 11-17-2009, 08:16 AM   #7
Kevin245's Avatar
One in the kitchen area by the entrance door.
One by the bed (Center bath model).
One in the TV cab.
Kevin
Eleanor Roosevelt
Old 11-17-2009, 08:16 AM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
We carry two . 1 1lb thats just inside the door on a bracket and 1/ 5 lbs both are ABC.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-17-2009, 08:18 AM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Ours came with one mounted near the door and another mounted on the wall in the bedroom. As I feel kind of good about that, it occurs to me that I should find it ironic that I don't know where the one in my house is.
I knew there was something else I needed from Home Depot today.
Pat
pmclemore is offline   Reply With Quote
Old 11-17-2009, 08:34 AM   #10
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
We have the one by the door near the kitchen but it never occurred to me to have one in the rear bedroom area. At first blush, it seems overkill to have two extinguishers to cover a 250 square foot space but maybe two is the right way to go. Thanks for the heads up.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 11-17-2009, 08:50 AM   #11
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Just a thought - if you're in the back of the trailer, and the stove/oven is the source of a fire, you really do not want to try and get past the burning stove to get to the fire extinguisher. Having a second one in the bedroom area is really cheap peace of mind insurance. One by the door is pretty standard, because you can reach it easily from both inside and outside. My 2 cents.
Chris
Old 11-17-2009, 09:51 AM   #12
warbler5's Avatar
2004 30' Classic
Roseville , California
Send a message via AIM to warbler5
We have 3....a large one kept in the closet, a small one in the bedroom, and a small one by the door, reachable from outside. All of ours are ABC (dry chemical)....however, a member of the AirForums, who is also a fireman, told us at a rally that we should have carbon dioxide extinguishers.
2004 30' Airstream Classic
2011 GMC 3500HD Duramax
Hensley Arrow hitch
Jackson Rancheria, 10-12 Oct 2014
Pinnacles Nat'l Park, 20-22 Feb 2015
Casini Ranch, 10-12 Apr 2015
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
warbler5 is offline   Reply With Quote
Old 11-17-2009, 10:22 AM   #13
funkill's Avatar
reno , NV
Images: 27
I had to look that one up. Looks like the CO2 extinguishers are for Class B & C also.
So, this leads me to another question. Seems most recommend the BC extinguishers. These fight the flammable liquid & electrical fires. Whereas the Class A is for ordinary combustibles (wood, paper, cloth). If you're fighting a fire caused by electrical - Class C, wouldn't you also need to extinguish the other parts on fire -Class A?
Thanks for all the ideas. I'm going shopping.
Laura
Old 11-17-2009, 10:42 AM   #14
_
lots of threads on this,
here is 1 with much good info.
http://www.airforums.com/forums/f44/...ent-34532.html
scroll to the bottom of this page for 5 more linked on the topic.
and don't forget to formulate a PLAN
it is perhaps MORE important than where u place the red can.
http://www.airforums.com/forums/f161...lan-15084.html
http://www.airforums.com/forums/f161...ted-17997.html
cheers
2air'
Best Fire Extinguisher and placement safari57 General Repair Forum 28 02-24-2012 05:40 PM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
No fire extinguisher? Kistler Our Community 5 09-18-2007 05:53 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Did you hit your fire extinguisher on the butt lately? femuse On The Road... 9 05-09-2003 10:15 PM
