Old 04-24-2014, 06:19 PM   #1
MyNancy1977's Avatar
Fiber optic light indicator on airstream
People have different feelings on this but they really work check my youtube video. Type( fiber optic airstream blinker). As long as they dont cut the cables while working on your light they will work.this is on our 1977 Excella 500 Landyacht. Hard process to fix the fiber cable.
Sent from my SGH-T999 using Airstream Forums mobile app
MyNancy1977 is offline   Reply With Quote
Old 04-24-2014, 10:14 PM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Mine work also, although I find that the Excella 500 emblem blocks my view of one of the turn indicators. They are visible at night when on the freeway. Not so much in city traffic due to headlights from other vehicles. Easy way to know if a bulb is out.
4RXLA is offline   Reply With Quote
Old 04-25-2014, 04:19 AM   #3
If you have the extended mirrors you can see them better.
Old 04-25-2014, 04:40 AM   #4
Maybe modifying a small magnificent glass in front helps, something that can be removed easily.
Old 04-25-2014, 06:01 AM   #5
1981 31' Excella II
New Market , Alabama
I had some broke cables and the part up front was falling apart. It was more of a liability as a source of leaks. There is a small plate over the hole now. One less leak is worth more than something of little value (AKA gimmick).
Perry
Old 04-25-2014, 06:38 AM   #6
1982 34' Limited
Harrowsmith , Ontario
I actually really liked the one on my '76, there was no problem seeing it in the daylight. I need to adjust the '82 as it doesn't work as well.
BradB is offline   Reply With Quote
Old 04-25-2014, 07:36 AM   #7
Fixing leak is important .ill enjoy my light while it works
Old 04-25-2014, 07:38 AM   #8
My cousion wish he had that on hes trailer hes been having rear light troubles and not a as.
Fiber optic light cable replacement? rippie Lights - Interior & Exterior 1 02-05-2014 06:15 PM
Tail Light Monitor (fiber Optic) DesertRat Lights - Interior & Exterior 15 02-27-2010 03:48 AM
Fiber Optic Indicator Light Cover Ganglin Lights - Interior & Exterior 58 01-10-2008 02:48 PM
L.E.D.s meet fiber-optic telltales Excella CM Electrical - Systems, Generators, Batteries & Solar 0 09-29-2007 04:32 PM
