Old 07-21-2015, 08:05 PM   #15
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
I had a Fiamma on my 25' Int'l CCD and i was concerned, although I never had a failure. The new 30' Classic though would not permit me to use a Fiamma because of lack of access to the rear storage and the blocking of the emergency exit while the bikes were installed. I went to a front receiver on my F-250 and it has worked out well for us. I also like the fact that if the Admiral and I want to leave the trailer and explore elsewhere we can take our bikes with us.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 02-06-2016, 11:07 AM   #16
dugster's Avatar
2016 28' Flying Cloud
Kennesaw , Georgia
Picking up our 28 FC in 2 weeks with Fiamma rack installed. I will trust the warranty but look for a place to mount an emergency strap as a back up. From what I understand, the large storage area in the rear twin allows access when bikes are not on the rack. I'm just not crazy about front hitches that catch all the bugs.
dugster is offline   Reply With Quote
Old 02-06-2016, 12:30 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have been using the Fiamma rack since they came out without problems. Several cross-country trips all over the country. It is easy to use, the bikes stay clean, and the weight at the rear balances some weight off the somewhat heavy tongue weight.
We tow with a softly-sprung Ram 1500 hitched with a flexible tapered round w.d. bar hitch, and set our Michelin 16" tire pressure at 65 psi of the 80 psi maximum. Have not experienced cabinets breaking, screws loosing or pulling out inside our Airstream, or trouble with the bike rack.
We used a similar Fiamma rack on our VW Camper and extensive travel for many years without issues. They have been a good product for us.
Doug and Cheryl
Old 02-07-2016, 06:33 AM   #18
1970 23' Safari
Ranchos de Taos , New Mexico
bikes inside
We haven't actually traveled with our Safari yet so I don't have any actual experience except watching my parents' preparations in the very distant past. Just wondering if it wouldn't be acceptable to put the bicycles inside the A/s on the floor or on a pad on one of the beds or couch? Normally the front wheels are easily removed and can utilize a smaller space. Tom
twh731 is offline   Reply With Quote
Old 02-07-2016, 06:54 AM   #19
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We plan to start by carrying them in the bed of our truck, to see how that works out, but based on research, it sounds like some people also use something like this inside their AS:
http://www.amazon.com/Racor-PBS-2R-T...=two+bike+rack
Although I think carrying them inside the AS is an interesting idea, it seems like it could be a hassle for one night stops.
SeaLevel is offline   Reply With Quote
Old 02-07-2016, 08:43 AM   #20
dkottum's Avatar
SeaLevel, we carry that Recor Bike Stand with us to park our bikes in camp, and in the back of our pickup to take the bikes exploring away from camp. It will not hold the bikes upright traveling without a heavy strap looped around the bike frame and fastened to the bed of the truck.
Yes, I think for traveling place to place, bikes inside would be a hassle. And Murphy's Law suggests sooner or later they will damage the Airstream interior. We use the Airstream Fiamma rack when towing. Our bikes provide local touring for us most places we stop, so they must be convenient.
Doug and Cheryl
Old 02-07-2016, 10:21 AM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
For years Airstream said you could not carry bikes on the rear bumper of an Airstream.
I designed and install my rake over 10 years ago. If you look at it you will see the vertical load is carried by the bumper and the rotational load, the one most likely to cause fatigue failure, is carried by the straps secured to the windowsill.
It is just poor engineering to expect a cast fitting to survive prolonged shock loads. Yes a better alloy would prolong the life but not eliminate the problem. Some form of compliance, the straps, has to be designed into the system.
Name:	bike rack 2.jpg
ID:	256952   Click image for larger version
Name:	Bike rack clip 2.JPG
2004 Excursion 4x4
Old 02-22-2016, 05:19 PM   #22
Parker , williamdcrockett
Both of my brackets broke exactly as shown in the photographs. One broke the first time I used the rack. Fiamma claims I installed them incorrectly and refuses to warranty them. I have traveled about 15,000 miles since I bolted those brackets back in-place with the same two bikes on the rack. I have had no problems but I will never buy another Fiamma rack because they refuse to acknowledge that the part is defective and they want me to pay $50 for each new bracket. I have no assurance that the new brackets will not break like the orginal ones. They do not stand behind their product.
wcrockett is offline   Reply With Quote
Old 07-04-2016, 06:31 PM   #23
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I've studied the photographs and wonder why did only one of the two flanges break, and happened to the pin, or rivet, that connected both parts? From the photos it almost appears the the pin slipped downward over time ultimately letting go of the top flange. If so the the bottom flange would have to take the full load and also be subject to a significant torque leading to failure.
I have the same Fiamma rack. I noticed that I happened to install one arm with the pin, or rivet, where the head is on top. The other I installed where the head is on the bottom. That one hasn't slipped but I'll be keeping an eye on it. Otherwise both parts seem okay.
kscherzi is online now   Reply With Quote
Old 12-27-2016, 10:10 AM   #24
Racine , Wisconsin
I know this is an old thread, but am very happy I found it. I will not be buying a Fiamma rack. Still trying to decide what to do about bike rack. HowieE's rack design is a super thought. Was thinking about an upper attachment to back of Avion. Strap makes a lot more since than rigid mount.
Kilroy is online now   Reply With Quote
Old 01-07-2017, 11:40 AM   #25
Cocoa Beach , Florida
Fiamma Bike Rack
We recently purchased a 20ft Flying Cloud and are avid cyclists. I would like to carry two 29 pound mountain bikes on the back of the F.C. I was going to utilize the Fiamma rack, however after reading these posts, I honestly not have concerns, and do not want to place the bikes at risk.
Are the any bike rack options that will allow us the carry them off the back? I have a F-150 with a low ARE cover that may carry surfboards. Any input greatly appreciated.
Happy New Year - Skip
Skip Stone is offline   Reply With Quote
Old 01-07-2017, 05:42 PM   #26
kscherzi's Avatar
Images: 24
I have the Fiamma rack on my trailer and have yet to have a problem. I carry two road bikes. Hundreds of miles.
Old 01-07-2017, 06:10 PM   #27
aftermath's Avatar
Spokane , Washington
I also have two bikes that we carry and have gone thousands of miles without an issue. As with all things, there will always be stories of things that go wrong. You need to look at the big body of evidence out there before you head off in another direction.
aftermath is offline   Reply With Quote
Old 01-07-2017, 08:23 PM   #28
dkottum's Avatar
Some Airstreamers have had their bike racks break and some Airstreamers have had lots of stuff break, come loose, and get thrown around inside their trailers. We have not had either and have towed a lot of miles traveling around the country for many years.
Doug and Cheryl
Fiamma Bike Rack for a 27 Classic DennisL Member Introductions 2 03-09-2014 08:31 AM
Fiamma Bike Rack kscherzi General Repair Forum 4 02-08-2014 07:49 AM
How to attach Fiamma bike rack to 19ft bambi Whitewater99 General Repair Forum 2 07-25-2013 04:49 AM
2010 Airstream International Signature 23D Travel Trailer WIth Fiamma Bike Rack eBay Watch Airstreams on eBay 0 05-27-2013 02:30 PM
EB Fiamma Bike rack StagrLee Eddie Bauer - All Models 2 05-08-2013 05:05 PM
