Old 10-08-2016, 08:47 AM   #1
2015 25' Flying Cloud
Tappahannock , Virginia
FC door latch bolt fell out!
Flying Cloud door latch bolt fell out after a bumpy ride and it looks like the backing plate (is this a plate with a threaded hole or a separate nut?) has dropped down inside the door jamb cavity! Any suggestions on how to repair this? Looks like I could remove inside trim but that may not give me access!
RivaHaven is offline   Reply With Quote
Old 10-08-2016, 10:21 AM   #2
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
Your photo motivated me to check my door latch post before I finished my morning coffee!! My latch post wasn't loose, but it wasn't tight either. Thanks!!
I have not worked on my door, but I have removed the door interior trim, inside handle, headache pad, and interior sheet aluminum rivets to access wiring inside the wall next to the door. Removing these parts is straight forward screw-and-rivet removal.
The door frame is tight to the end wall rib. Removing the interior pieces mentioned may allow you to retrieve your part. If you can't get the part out you may have to remove the door frame.
Also, the threaded part that fell was probably secured with rivets or screws to either the end wall rib or door frame. Perhaps you can see the means of attachment thru the hole the latch post occupied.
Good luck! Let us know how you solved the problem.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 4 06-21-2016 10:31 AM
Sliding pocket door - rail screw fell out ? OffbeatRVing General Repair Forum 16 12-10-2015 07:00 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
dead bolt and latch pin BigAl Doors & Locks 1 04-04-2005 02:23 PM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 12:07 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
