Old 04-18-2014, 09:41 PM   #491
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by ZoominC6 View Post
How about a screen door handle we can get our hands around? We love this little mod.
Hi, changing the screen door handle makes a huge difference. I was able to change mine to one that matched the rest of my cabinet handles. I couldn't get my fingers in the factory screen door handle.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-19-2014, 05:32 AM   #492
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I made similar mod for show, I built a 40" square of piping and use a tarp cut to correct height and shower curtain hooks. My roof if needed was beach umbrella minus the pole kept on via bungee. It worked great, on one side door of my teardrop.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-19-2014, 09:52 AM   #493
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I just peeled the Thor sticker off my AS on a warm sunny day. Our 2014 trailer hadn't suffered any damage from the infamous Thor sticker, but I saw it just sitting on the trailer, which was warm enough to soften the glue and the decal...it just peeled right off, no fuss, no muss, and the trailer looks happier now.
I also made our trailer into an LRF-compliant device by applying Little Rubber Feet to the sliding cabinet doors above the galley so it has a little more friction on the slide. We're hoping that will solve the problem of those doors sliding open during travel. Lastly, we added the same LRF to the frame of the bathroom door. Now it doesn't rattle every time someone walks by, and instead closes quietly and gracefully.
Rocinante is our 2014 International Signature 27FB
Old 05-08-2014, 12:09 AM   #494
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
Here are two photos of an inexpensive mod I just made.
Splatter on the veneer beside the range top has been a mild concern. We first thought of covering the whole partition with aluminum sheeting and I troubled myself with thoughts of how to attach it, how to make it lie flat etc etc....
An ad in the local paper solved those problems! I found some aluminum tiles with a self adhesive backing that we think worked out quite well. Judge for yourself.
While you are judging, look at the last photo which was another wonderful mod - perfect for an Airstreamer - for under 5$ which we enjoyed while admiring our work!
ID:	211445   Click image for larger version
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 05-08-2014, 09:06 AM   #495
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
Love the aluminum tiles. Where did you find hose? Looks like a perfect solution for my bath shower wall! Thanks!
albert is offline   Reply With Quote
Old 05-12-2014, 01:34 AM   #496
triterra's Avatar
1969 27' Overlander
1976 Argosy 28
Lodi , California
Added shelving with drawers (amazon $55) to the pantry. Now there is room for veggies and fruit in the lower basket and bread on the shelf. Added a second wood shelf up above. Then I got a two pack of automatic motion sensor battery LED lights (costco $20) for the pantry in the A/S and in the house. Now you open the doors and go ahhhhhhh because you can actually see what's in there!
ID:	211739   Click image for larger version
triterra is offline   Reply With Quote
Old 05-13-2014, 12:56 PM   #497
RMB
RMB's Avatar
Re tiles:
They are made by a company called "STILEST".
They come in vertical or horizontal , long or short grain and are available in aluminum or stainless steel They consist of two pieces of metal with some kind of sandwich material in between - about 1/8" thick.
I experimented with one tile and banged it with this and that to see if it would dent....short of a hammer blow or a chisel, no dents. Its not fragile.
They are easy to cut - band saw, hack saw, scroll saw - leave a clean edge and are bendable. To go around corners the manufacturer suggests using a router to cut a v notch on one side or a round groove depending upon the corner you want to wrap.
Cheers!
Old 05-13-2014, 03:05 PM   #498
2004 30' Classic
Hillsborough , New Jersey
modification for under $100
Replaced the two fluorescent lights in the bathroom with 2, 12 volt bulb units. The fluorescent lights didn't always work properly when using battery power, so now I don't have that problem anymore!
Also replaced the light in the shower area with a slightly yellow colored LED bulb which we use as a "night light" when we camp with only battery power.
wolf146 is offline   Reply With Quote
Old 05-13-2014, 04:11 PM   #499
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Favorite Mod Less than $10
This was an easy change that almost doubled the available storage space under the refrigerator. It also takes care of the annoying problem of the drawer coming off the flimsy track.
First, I removed the drawer front from the drawer box, removed all the slider track hardware, added hinges & a closure and.wala we have a cupboard that's much bigger than the drawer. (8" wider, 6" deeper, 6" taller)
Down the road, I'll ad a back board, & some sort of dividers or organizers. Might even put a wine rack in there.
ID:	211858   Click image for larger version
Schools Out is offline   Reply With Quote
Old 08-05-2014, 07:16 AM   #500
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
Folding Stool
Hello Airstreamers!
I found this folding stool and I must say that it's awesome! Folds flat, not heavy and provides a place to sit (I use mine in the kitchen). Who doesn't need an extra place to sit?
Amazon.com: TG 82-0827 24-Inch Cushioned Folding Stool, Black: Home Improvement
I even bought one for my house kitchen and I use it all the time! Price? Such a deal at about $25.00! Wt. limit ~300 lbs.
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
Old 08-05-2014, 12:43 PM   #501
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
+1 for the stool! About 2 years ago I picked up the identical stool at an estate auction for $5.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 08-05-2014, 04:46 PM   #502
Medina , Ohio
You've got to love those estate auctions! Bravo on a great find!
Old 08-05-2014, 06:54 PM   #503
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
About 3/4 hour south of where we live there is a weekly estate auction - not every auction is loaded with goodies for us, but there is variety. Ken Finnerty also sold my AS LY motor-home for me when I bought my current 32-ft Excella. Generally it's a weekly affair and it is really quite entertaining, especially when Ken gets gets ticked when there is too much chatter - he'll often say "Cut the noise, I'm here to see this S--t!"
VE3JDZ
AIR 12148
WBCCI 8080
Old 08-07-2014, 03:31 PM   #504
2004 30' Classic
Mod for under $25
Bought 8 interlocking 12 x 12 inch vented tiles 1/2 inch thick. I placed them in the rear outside tray where I store the outside rug. Once in a while some water gets into the tray and even though I have drilled holes in the bottom the rug gets wet. These tiles should keep the rug above any water that might accumulate in the tray.
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 09:50 AM
Others' Reactions to your Airstreams? Pick On The Road... 84 05-16-2007 12:49 PM
Post your favorite picture of your MH PeterH-Airstreamer Airstream Motorhome Forums 42 07-24-2004 09:13 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Vintage campers My favorite site !! airstreamcaravel Link Archive 0 02-25-2002 04:42 PM
