Old 01-26-2014, 09:41 PM   #477
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Acrylic screen covers for the screen door. Allows you leave the main cabin door open in cool or hot weather.
Here's the link to a thread detailing the install.
http://www.airforums.com/forums/f454...or-115281.html
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 03-12-2014, 05:12 PM   #478
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Lots of mods, most are less than $100. Current favorite, use it every day in any wx, is the Salem (or Ram) vent installed low on curbside wall between sofa and door. Lets fresh air in, keeps bugs and rain out. Technical name is two-way hingeless vent, I think. Installed it to vent the catastrophic heater (thx to AZflycaster for that heater name), but found out we like having this fresh air coming in all the time.
Installation took two hours, parts cost south of $75 unless purchased from Airstream Co (then parts are over $100). Does this knock me off this page? I didn't buy from AS, we found a cargo trailer builder in Elkhart who sold to us. Same thru-wall vent commonly used in FreightLiner and other sleeper cabs.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-12-2014, 11:32 PM   #479
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, pictures please.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-13-2014, 07:16 AM   #480
1981 31' Excella II
New Market , Alabama
That flap door on mine leaked like crazy when there was a hard blowing rain. I ended up patching it up till I can find the time to redesign it and put a scoop on there instead of the door.
You have a bad exterior rivet to the lower right of your flap door. I had leaks on both sides of the door from loose rivets. A little Parbond fixed that problem. The black powder around the rivet is a telltail sign. I have seen this on my trailer and others. The constant opening and closing of the door loosens the rivets.
Here is my cheap fix.
Perry
Originally Posted by blkmagikca View Post
Earlier trailers (like my 1987) have a lever alongside the vent that opens a flap on the outside. The fan is engaged when the lever is slid to open.
Old 03-14-2014, 12:32 PM   #481
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Thanks for the heads'-up perryg114. I looked at the rivet in question - it is not loose, and the black "powder" is not loose at all. I'll be in JC in 3 weeks for my regular servicing and I'll ask them.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is online now   Reply With Quote
Old 03-14-2014, 03:08 PM   #482
1981 31' Excella II
Try to stick your fingernail under the rivet heads around both sides of the door. You can see a black streak on it. Most of mine were on the right side of the door and some sneaky ones at the bottom of the door frame. If you can't get a nail under it then most likely it is good.
Perry
Old 03-14-2014, 09:14 PM   #483
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Can't get a fingernail under any of those rivets, Perry. They all look fine to me.
VE3JDZ
AIR 12148
Old 03-14-2014, 10:02 PM   #484
1981 31' Excella II
Sometimes I like being wrong. Good deal.
Perry
Old 03-29-2014, 08:55 PM   #485
Hoonanea's Avatar
2012 23' International
Riverview , Florida
I made an outdoor shower curtain rod out of PVC pipe, elbows, and couplers. The short sections are held in place mostly by friction but couplers on the end fit nicely over the round button of the suction cups. They are the kind that have the red ring to let you know if it is coming loose.
The longer piece fits in the crevice under the awning where the top fabric meets the roller tube. I used two lightweight microfiber shower curtains and some basic rings to put it all together. It isn't terribly roomy but it works. I will use some binder clips tied to soda bottles filled with water to weigh down the bottom hem and pull it out away from the trailer a little for some more room. The total cost is less than $50.
Name:	ImageUploadedByAirstream Forums1396144449.396717.jpg
ID:	208535Click image for larger version
Name:	ImageUploadedByAirstream Forums1396144466.016358.jpg
Ho'onanea -- to pass the time with peace, ease, and pleasure.
Hoonanea is offline   Reply With Quote
Old 03-29-2014, 09:07 PM   #486
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
It cost $9 per storage area access lock to get them re-keyed away from the ubiquitous CH751 tumblers. I had them keyed to the truck camper shell lock pattern and reduced the number of keys for trailering I need to carry by one.
Old 03-30-2014, 10:59 AM   #487
bolerama's Avatar
Saskatoon , Saskatchewan
Images: 30
Super Shower!
Thanks for this great idea. Our grey tank on our 23D fills quickly, so we were thinking of using that outdoor shower more effectively. Very innovative. Too bad we don't have side awnings, but we will one day.
Lisa
Attachment 208535Attachment 208536
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 03-30-2014, 11:08 AM   #488
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
I think post 478 refers to this style of 2 way vent Robert? I have installed these on my CLIPPER rear cargo bay doors to assist in air flow and cooling.
They are available from any trailer supply, including eBay.
8" x 12" Aluminum Air Vent Two Way Pop Up Horse Trailer Cargo Salem Side Wall | eBay
You can get various interior trim rings to match your decor? These used to be standard cab vents on over the road trucks before the integrated HAVC systems became standard.
Dave
Name:	2 way vent 812dblpopupalT1.jpg
ID:	208578   Click image for larger version
Name:	2 way vent 812dblpopupalT2.jpg
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 04-18-2014, 03:41 PM   #489
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
http://www.thegoodsurvivalist.com/ho...-easy-to-make/
I haven't tried this yet but can imagine it would be very helpful in hot summer days as a supplement to the ac!
Old 04-18-2014, 04:40 PM   #490
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
How about a screen door handle we can get our hands around? We love this little mod.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 10:50 AM
Others' Reactions to your Airstreams? Pick On The Road... 84 05-16-2007 01:49 PM
Post your favorite picture of your MH PeterH-Airstreamer Airstream Motorhome Forums 42 07-24-2004 10:13 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Vintage campers My favorite site !! airstreamcaravel Link Archive 0 02-25-2002 05:42 PM
