Old 10-23-2010, 09:42 PM   #239
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
How did you get the front cover/bezel off?
drew05 is offline   Reply With Quote
Old 10-23-2010, 10:01 PM   #240
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, very carefully; If you use a flat bladed pocket screw driver and put in at the top, in the center, and between the black bezel and the face plate, you can pry it open. There is a metal spring clip on the top and two tangs on the bottom. After you pry the top open and pull it toward you enough for the center screw to clear the bezel, it will then lift up far enough for the two bottom tangs to clear the bottom of the black bezel. The rest is disconnecting the wires. If you look at the picture showing the back side of the panel, you can see the spring clip and two tangs. I removed the black bezel, [four screws] to make clearance for the LED light. You should be able to see where I made clearance on the bezel.
Name:	IMG_3207 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-24-2010, 03:05 AM   #241
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Originally Posted by ROBERTSUNRUS View Post
Hi, this has been in my mind for years and today I made it happen. We are sick and tired of not knowing if the water pump switch is in the ON position or the OFF position...... especially now that we will know if the water pump is ON or OFF. [note: RED means it is ON]
NICE ! Do you have a couple more pix of which wires go where ?
T & K
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 10-24-2010, 09:11 PM   #242
Salem , Oregon
Images: 18
T & K
Hi, no I don't have pictures of the wiring, but I will explain it like this: In the bottom left corner [in this picture from the back side] is the back of the water pump switch. There are three wires connected to the switch. These wires are: from left to right, GREEN, YELLOW, and PURPLE. The yellow wire in the center is the hot/power wire. The green wire does not connect to anything. And the purple wire goes to the water pump. Connect the red wire from the LED to the wire nut on the purple wire. Connect the black wire on the LED to the black wire going to the control panel.
2005 Safari 25-B
Old 10-25-2010, 07:08 AM   #243
B4WEDI's Avatar
2006 19' Safari SE
Thumbs up Yeppir !
Thanks Bob ! I doesn't sound so scary after all ! I'll swing by radioshak en route and see what they have for appealing little lights and give this a go.
Thanks for a great idea, the pump on / off question has always been a bugaboo for us..... I'll let you know how it goes !
T & K
T & K
Old 10-25-2010, 09:29 AM   #244
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Bob, I don't have my airstream here, but it had looked to me like the actual pump switch was modular in the faceplate. Has anyone found a lighted switch to be used as a snap in replacement?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-25-2010, 12:43 PM   #245
Westfalia's Avatar
Images: 35
This looks like the right switch, but I'd need to confirm before buying. This is not lessen the impact of Bob's mod, I just hate drilling .
http://www.wiringproducts.com/contents/en-us/p998.html
Old 10-25-2010, 04:24 PM   #246
B4WEDI's Avatar
2006 19' Safari SE
Possible switch swap....
Chris..... the switch on the panel of my '06 looks identical to the one in Bob's excellent pictures. The wiring colors he described match exactly also. Closer inspection of the switch shows that it is made by Sigma.
ROCKER SWITCHES by SIGMA / SPDT SPST DPST DPDT Momentary, Lighted, Waterproof & Miniature (Mini)
I just sent them an email with the question you posed.
I'll post my findings here.
T & K
T & K
Old 10-25-2010, 09:50 PM   #247
B4WEDI's Avatar
2006 19' Safari SE
Thumbs up Lighted Sigma Pump Switch
*** Question posed ***
"Hello, I have one of your switches ( LR-20985) in my Airstream travel trailer that turns a 12V water pump on and off. It is black in color. I would like to replace this switch using the existing faceplate with one that is illuminated to show that the pump is on."
*** Answer from Sigma ***
"The part no is 001A-31. You will have to run a ground wire from somewhere to the offcolor tab. get it at www.burnstines.com "
Lighted Rocker Switches - Rocker Switches - Low Voltage Switches - Switches - Electrical
http://www.burnstines.com/catalog/pr...compare/index/
T & K
T & K
Old 10-25-2010, 10:19 PM   #248
Salem , Oregon
Images: 18
Hi, I had thought about a lighted switch, but I didin't find a direct replacement one, [didn't look real hard] and is the switch lighted all the time or lighted when in the ON position? Those were some of my concerns. Let us know what you do.
2005 Safari 25-B
Old 10-26-2010, 09:06 AM   #249
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Compare Products List - Burstine's Distributing Corporation
T & K
[/QUOTE]
I have a 2010 Sport 22fb, where could I ground this to?
Gary
Castaway is offline   Reply With Quote
Old 10-26-2010, 10:03 PM   #250
Salem , Oregon
Images: 18
T & K
Gary[/QUOTE]
Hi, connect it to the black wires; They are the ground for this system.
2005 Safari 25-B
Old 10-26-2010, 11:37 PM   #251
Westfalia's Avatar
Images: 35
Great work on the find guys! This will be a nice sub $10 mod!!!
Old 10-27-2010, 12:15 AM   #252
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Great mod. Thanks for the wiring details, and the source of the rocker switches. I love lights, and may go for the blue one. It'll look nice with the fresh water light, which always seems to be flashing red.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 10:50 AM
Others' Reactions to your Airstreams? Pick On The Road... 84 05-16-2007 01:49 PM
Post your favorite picture of your MH PeterH-Airstreamer Airstream Motorhome Forums 42 07-24-2004 10:13 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Vintage campers My favorite site !! airstreamcaravel Link Archive 0 02-25-2002 05:42 PM
