Old 09-18-2010, 10:50 AM   #225
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Not really a mod but we bought a very small (fit in your hand) Veho wireless speaker. It runs off the new stereo that has a USB! it works great and it was only $49.00! I wanted something easy and small and this little guy sounds pretty good for the money. I really wanted the Bose wirless with usb but $550.00 for the camper seemed excessive!
blmitch5 is offline   Reply With Quote
Old 09-29-2010, 02:21 PM   #226
Wise Elder
Jammer's Avatar
2010 30' Classic
Photos to come, but I made a number of minor yet important mods:
1) Added a clock. ($20)
2) Added an indoor-outdoor thermometer. ($16)
3) Changed the TV and thermostat around from their stock configuration by replacing the TV mount with one that is thinner, and moving the thermostat down so the TV doesn't have to be moved to get at it. ($24 for new TV mount)
4) Not installed yet, but planning to add a bypass switch to turn on the running lights from inside the traylah in those situations when a visitor is having trouble finding the rig at night.
5) Painted the heating vents and doorbell cover so they blend in better.
Old 09-29-2010, 02:49 PM   #227
I was interested to read the above post from Jammer. My 1987 Excella was fitted as standard with a clock, an inside/outside thermometer, two outside white flood-lights switchable from inside, and the outside vents were all clearcoated aluminum, matching exactly the rest of the trailer. When I fitted a TV, I did not, of course, cover up the thermostat. To my simple brain, this hardly appears to be 23 years of progress.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-29-2010, 03:36 PM   #228
Wise Elder
Jammer's Avatar
2010 30' Classic
Indeed.
Perhaps whatever junior engineering intern they had do the TV mount could take a lesson from you in proper design.
The heating vents and doorbell cover to which I refer are the interior portions. They arrived from the factory in bright white and I painted them tan.
Old 09-29-2010, 03:38 PM   #229
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Can we see a photo of the painted parts now?
GREENovaters is offline   Reply With Quote
Old 09-29-2010, 04:50 PM   #230
Wise Elder
Jammer's Avatar
2010 30' Classic
I'll have one by and by. I'm still using film, and while I've taken one to share with you, I still have to finish out the roll.
Old 10-01-2010, 11:05 PM   #231
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Water pump silencer kit.
Hi, as most of you know Airstream uses PEX directly to the water pump, making it noisy. This is due to vibrations from the pump. To further make the noise outrageously loud, I made plywood filler boards to help keep mickey mouse out of my trailer. And this held the PEX pipes even more rigid. I wanted to buy the silencer kit, but the hoses come with straight ends and my water pump uses 90 degree angled ends. So I decided to make my own. I disconnected the pipes from the water pump. I cut the copper ring off at the out-put PEX at the 90 degree end fitting. And I cut the copper ring off at the filtered end of the filter fitting. I need one brass 1/2" connector, four hose clamps, and six feet of hose. Here's the problem: The 1/2" hose fits way to sloppy and the 3/8" hose is too tight. How can this be? Well 1/2" PEX is actually closer to 12 mm, so I decided to force the 3/8" hose onto the connectors and use hose clamps on them because the copper rings are either too small or too large. This kit, or parts, that I used cost less than $10.00 and when fully tested the noise is way down and there were no leaks.
Note: I did have to use only one copper ring; I bought a bag of rings when I bought the crimping tool for my bathroom faucet change.
Name:	IMG_2398 (Large).JPG
ID:	112117   Click image for larger version
Name:	IMG_2399 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-03-2010, 04:27 PM   #232
Hibby's Avatar
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 14
Bob,
That's a GREAT idea... My wife and I thought perhaps our water pump had been built with an offset cam to make it rattle so that you knew it was running.
It's so loud that you can't flush the toilet in the middle of the night without waking up your spouse, let alone anyone in the nearest campsites. Seems to me that Airstream should be paying close attention to these forums to gather ideas for refining and improving their product.
Hibby
Hibby is offline   Reply With Quote
Old 10-03-2010, 07:01 PM   #233
lwp99's Avatar
Gold Canyon , Arizona
water pump noise
Similar to what Bob did for noise reduction, I also added a small accumulator to reduce the pump cycling under low load.
Link to piping changes.
- Larry
lwp99 is offline   Reply With Quote
Old 10-03-2010, 11:15 PM   #234
Salem , Oregon
Images: 18
Hi, Larry. Your trailer looks familiar! I might add an accumulator too. I noticed a surge in pressure, but only in the shower head.
ID:	112330   Click image for larger version
2005 Safari 25-B
Old 10-04-2010, 12:05 AM   #235
lwp99's Avatar
Thanks!
I like what you did! I've since changed out the original fold-out bed to something more like what you have. And have mounted a flat screen above where the corner cabinet was originally installed.
There are larger accumulators than the one I installed; you might want to consider one of them for a little longer time between pump operations. There appears to be enough space to mount one adjacent to the pump.
I could not insert photos for some reason today; thanks for finding and inserting them!
- Larry
Old 10-16-2010, 07:24 AM   #236
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I just found a thread for some cheap home made air blow out kits for winterizing your water system. They seem to fit right in here. Use this link to see them. http://www.airforums.com/forums/f458...tml#post906927
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-23-2010, 08:48 PM   #237
Salem , Oregon
Images: 18
Huge difference for two bucks.
Hi, this has been in my mind for years and today I made it happen. We are sick and tired of not knowing if the water pump switch is in the ON position or the OFF position. Today I bought a 12 volt RED LED from Radio Shack for $2.00 and I am sooooo glad that I did. Drilling a hole in the control panel was touchy. A bit of the gray top layer of the panel lifted or changed colors slightly, but I can live with that especially now that we will know if the water pump is ON or OFF. [note: RED means it is ON]
On this last trip I decided that I need a place to put my wet, soapy sponge, before, during, and after I do the dishes; So I went to Bed Bath & Beyond and found a sponge holder and soap container all in one piece. This was about $16.00 and it also will make life in the trailer a bit easier.
Name:	IMG_3205 (Large).JPG
ID:	113844   Click image for larger version
Name:	IMG_3206 (Large).JPG
Name:	IMG_3207 (Large).JPG
ID:	113846   Click image for larger version
Name:	IMG_3209 (Large).JPG
Name:	IMG_3211 (Large).JPG
2005 Safari 25-B
Old 10-23-2010, 09:32 PM   #238
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Like the light for the water pump switch...makes sense...
And we have the very same sponge & soap holder!
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Favorite Jerry-Rig? Dave Cole General Repair Forum 58 10-07-2013 10:50 AM
Others' Reactions to your Airstreams? Pick On The Road... 84 05-16-2007 01:49 PM
Post your favorite picture of your MH PeterH-Airstreamer Airstream Motorhome Forums 42 07-24-2004 10:13 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Vintage campers My favorite site !! airstreamcaravel Link Archive 0 02-25-2002 05:42 PM
