Here's a good on for you: You know that plastic cover that protects the P trap which is exposed, underneath the '67 Caravel. Well mine was completely rotten and broken (besides how is thin plastic supposed to protect a plastic P trap?), anyway I replaced it with my dogs stainless steel dish! it fit PERFECTLY got it at Pet Pals. PS: yes, I got the dog a new dish.
Sue
just lookin for John Wayne
Martin and O'Brien
Thanks for the pointer but that is not what I am looking for. I am looking for the aluminum trim that is paited blue in the middle.
You can see it on the pictures above.
My ol' 71 did not have rubber insert in it.
Andy at inland tells me that this stuff has not been made in 20 years and I would have to find salvage material.
Thanks anyway,
smily
__________________ Ken Smillie
My 1994 36' Classic MH is for sale See it in the classifieds
Anyway the panels are hinged in the front, (see vertical rivets near propane bottles), and the back side has standoff brackets,(you can see the two polished capnuts above the reflector).
The hinges are 90 degrees to the skin and a piece of angle mounted to the panel and the hinge creates a C Channel.
The hinges facilitate access for cleaning behind the panels. You simply remove the two capnuts and the whole panel swings out to the front, kinda like wings.
I think I will find a TV antenna that resembles a light saber.
Han Overlander
Ken Smilie,
Here's what I did on my 71 Safari as regards the aluminum trim with blue inside the molding. I masked off the molding with two inch masking tape and then trimmed out the blue strip area with a sharp knife and removed that part of the tape. Coverd the trailer sides with masking tape and then sprayed the area with Rustoleum Royal Blue paint. Turned out to look just fine. Couldn't use the insert anyway since it didn't have it in the first place.
Dan
After reading this forum for about a year I purchased a 1987 34 ft side couch, twin bed Excella. The unit is in very good condition, but after 18 years show some signs of wear. I plan on spending the next year on this project, polishing the exterior, new curtains, upholstery, pergo flooring in kitchen and living room, And checking everything in great detail, hoping it will perform well for another 18 yrs . I purchased a set of Segment protectors, or gravel guards privately, and am looking for any information or specs, on the proper mounting. Does Airstream use backing plates on both sides of the skin, for the hinge and non-hinged sides of the segment protectors? JIRA
