Old 04-03-2015, 04:06 PM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think it's a plus to have them. I'm a bigger fan of MaxAir fans and they have that feature. I changed out one of my fantastic fans last year and will probably do the other one this year.
2012 Dodge Durango Hemi/AWD
Old 04-03-2015, 04:11 PM   #16
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I like the reverse feature on our Fantastic Fan, but we usually use it as an exhaust fan. I used it most when a maple tree's seed pod (one of those whirlybird things) got stuck between the fan blades and the fan housing. Had to run that sucker on hi both ways to break it loose!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-03-2015, 04:20 PM   #17
dznf0g's Avatar
Oswego , Illinois
I just use the "in" on the lounge fan in conjunction with the "out" on the bedroom fan to purge the heat after travel or being shut up. Makes the a/c cool down time much shorter. If I'm using just fans with windows open, I keep both fans on "out".
-Rich-
Old 04-03-2015, 04:32 PM   #18
gecko's Avatar
2009 28' International
Pacific Palisades , California
Originally Posted by gandttimes View Post
Sorry if this has been asked and answered before.
Thinking of upgrading one (or both?) of my Fantastic fan units to have a reverse feature.Has anyone who has this found it to be useful? Right now both of my fans only expel. Wondering if it is useful to have the draw air in?
Thanks.
We ordered two for our 28' International. They have the rain feature, but only blow out. We have not found this to be an issue, as it was explained to us that Airstreams are relatively airtight, and you can control the flow of air very nicely by opening or closing either just the other fan, or one window only (if the weather is not nice.) The awning windows do allow you to open one of them when raining (as long as it's on the downwind side of the AS!) and you are onboard. A little experimentation with which single window to open to use the fan to create suction and a directed air path makes everything quite comfortable.
gecko is offline   Reply With Quote
Old 04-03-2015, 04:55 PM   #19
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by WindyJim View Post
One other comment, and that is I was kinda cautioned away from the Fantastic fans that automatically close if it rains.
I live and camp in drier climates so rain is normally not an issue. The reason I was recommended against the rain sensor models is that if a leaf or other item falls on the sensor the fan will shut down and close, thinking it is rain.
I would rather know that the dog (in our absence) still has ventilation and run the slight risk that we might get some moisture in the AS, than think the dog has ventilation and find that is not the case.
If we camped where it rains a fair amount, I might choose differently, but for us the model that reverses and has a thermostat was the best choice.
Not too worried about the closing of the fans in rain as we will be putting a couple of Maxxair II's up there. I like what has been said about having the fans for pushing a bit of air onto the dining table or into the bedroom.
All of the responses are great. Food for thought. Like sitting around a campfire. Thanks
George
gandttimes is offline   Reply With Quote
Old 04-03-2015, 05:31 PM   #20
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Of you pull down the manual twist to open knob it disables the rain closing feature.
kscherzi is offline   Reply With Quote
Old 04-03-2015, 05:47 PM   #21
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have a FF in the front and a plain vent (no fan) in the back (over the bed). First I considered replacing the plain vent with a FF, but then decided to first rewire the forward FF with a reverse switch and see how that worked for us. It solved our issues! We still have the plain vent in the back but can now easily control the airflow using the front FF now. We usually run it in the "out" mode, but there are times when the reverse mode is useful.
TB & Greg and Abbey Schnauzer
#3954
Old 04-03-2015, 07:31 PM   #22
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Too right. Forgot that move.
George
Old 04-03-2015, 10:50 PM   #23
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
In our '99 Casita we had the FF w/rain sensor, temp, in/out .
On our maiden trip we left the vent wide open. While we were out and about a thunder storm moved in and dumped , The FF automatically closed no water came in
Our 04 Casita had the FF w/ Temp, in/out. I did add a Maxx Air vent cover so we could open the vent and run the fan in the rain. If you don't have one get one.
Our 01 Casita has the FF w/ Temp , in/out. I added a MaxxAir vent cover.
On using the IN mode , It makes a great hair dryer after your shower
Our '69 Tradewind I changed out the stock vents to Maxx Air Automatic remote controlled power vents with the built in automatic cover w/ in/out, temp.
I find them quieter and have more speeds then the FF.
I shopped around and found them on Amazon for less then anywhere else I looked.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 04-10-2015, 01:18 PM   #24
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Does anyone out there have any experience using the Camco 40431 RV vent cover? Found a screaming deal on them but I know nothing about about them.
George
Old 04-10-2015, 02:18 PM   #25
PaulnGina's Avatar
Good Ol' , USA
George
I have a couple of those on our 1987 Avion. They are easy to install: drill some holes in the existing vent frame, mount some brackets to the frame, then attach the Camco cover to those brackets. Piece o'cake. You'll still have the full function of the existing vent cover.
1987 Avion 34W
Old 04-10-2015, 02:56 PM   #26
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I just saw in Camping World, vent covers made by Fantastic Fans!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-10-2015, 03:00 PM   #27
lewster's Avatar
Naples, FL , Hood River, OR
Maxx Fans have an integrated cover that is part if the fan. Doesn't stick up from the roof and look really ugly. They allow operation in the rain and have multi speed and in/out selector right out of the box.
Put 2on my '06 19 CCD and never used the A/C.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 04-10-2015, 03:18 PM   #28
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
The only criticism that I can find so far about the Camco is that they don't allow the vent cover to go all the way up. Do the MaxxairII's allow full opening of the fantastic vent?
George
Fantastic Fan Reverse Flow Switch 2dabeach 2007 Safari SE 5 10-08-2014 03:54 PM
Fantastic fan does not work in reverse djpierce Roof Vents, Skylights & Fans 18 09-24-2013 02:27 AM
Fantastic Vent reverse switch bolerama Roof Vents, Skylights & Fans 77 03-24-2012 08:11 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-12-2006 11:11 PM
