11-16-2015, 07:25 AM
83 Excella - 27
1983 27' Excella
Temecula
Fantastic fan not so fantastic
I installed a new Fantastic fan.I am able to manually open it and turn it on. The thermostat seems to work.
How do you make it open or close with the motor?
Or, does it only close with the motor if it senses rain?
11-16-2015, 07:57 AM
1988 32' Excella
Ojai
There is a small black switch near the motor. That is for opening and closing.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 300k+ (The Beast)
11-16-2015, 08:11 AM
2012 25' Flying Cloud
Battle Lake
On ours you have to push up on the manual opening knob to engage the motor.
Doug and Cheryl
11-16-2015, 09:48 AM
Mantua
, Ohio
Don't those things come with instruction booklets?
11-16-2015, 11:07 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The Fantastic fans changed the lid motor between 2014 and 2015 so it will not disengage from the gear train. Now you have to force the motor as well as the gear train to open and close the lid manually.
Since I do not like the Fantastic fan should we installed on the Classic to keep the rain out when the Fantastic lid is open, I switched the 23D to the Maxxfan 7000K and will do so in the Classic next spring.
11-16-2015, 11:13 AM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Sounds defective. The new ones have been problematic. We received three mother boards before getting one to work.
Antique Pedaler
2021 Caravel 20 FB
11-16-2015, 11:36 AM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Call the folks at FF. they are great to deal with.
George
11-16-2015, 11:42 AM
2012 30' International
Livingston
Make sure the rain sensor isn't wet or damp
11-16-2015, 01:01 PM
2009 28' International
Pacific Palisades
All good advice.
It will only open or close with the motor if it sense rain OR if you turn it off by using the small on/off rocker switch.
Our preferred methodology for our 2010 models is to make sure the large speed switch is on one and that the small on/off rocker switch is set to "on." Then we rotate the thermostat knob towards the blue or cold and the fan will open and turn on. On the older models, you pulls the "geared" knob down to disengage it from auto function and push it up to engage auto function.
If all else fails, check with the mothership--the Fantastic Fan techs are friendly, knowledgable, and helpful.
