Old 08-13-2014, 07:26 PM   #1
2009 30' Classic
madison , South Dakota
Fantastic fan discoloration help
Our 2009 Classic has had some "rusty" looking discoloration on the inside panel of both fantastic fans since we purchased it last year. My understanding is that it is due to adhesive overspray at the factory. Has anyone had any success in cleaning these panels? Haven't tried any thing yet.
jackcat is offline   Reply With Quote
Old 08-13-2014, 07:34 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good question. I have noticed the same on mine. I tried some general purpose cleaner and it did not make a dint in it.
MICHAEL
Old 08-13-2014, 08:46 PM   #3
dznf0g's Avatar
Oswego , Illinois
Yes, mine had it too. Believe it or not, I undressed the panel of all switches and used a Black and Decker mouse sander with fine sandpaper. Worked great! Just use light pressure and don't "burn" it. Came out snow white.
-Rich-
Old 08-14-2014, 04:54 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Here's an off-the-wall suggestion— Toothpaste! It's a polishing compound, after all, cheap and readily available.
And as a bonus it will make your fan smell minty fresh!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-17-2014, 06:03 AM   #5
2009 30' Classic
Thanks for the replies. I'm going to call JC to see if they have any suggestions. If it is due to their over spraying of glue, they must have some way of cleaning their equipment.
Old 08-17-2014, 06:06 AM   #6
dznf0g's Avatar
Oswego , Illinois
I don't think you'l find a chemical solution that won't destroy the plastic.
-Rich-
Old 08-17-2014, 07:30 AM   #7
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I pained ours silver and it looks a lot better.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Discoloration Of Door Vinyl rfield54 Upholstery, Blinds, Walls & Interior Finishes 3 09-21-2011 05:49 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Weird Discoloration evsjr Roof Vents, Skylights & Fans 3 08-03-2009 08:51 PM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
discoloration of exterior aluminum funkill Clearcoat, Exterior Paint & Trim 0 06-03-2009 09:58 AM
