Old 07-15-2013, 11:53 PM   #15
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Sorry, but that's not exactly true!
Yes, but I wasn't writing for a technician, just providing sufficient reasoning to stop the intended behavior declared in the thread. I used 'component' with the meaning "a constituent part of" which is my bad since I know the difference.
Long responses on a cell phone are tough.
SeeMore is offline   Reply With Quote
Old 07-16-2013, 08:22 AM   #16
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Silver Goose View Post
The original fuse that is installed in both of my FF is a 4A Slow Blow. That being said, FF sells a number of models that essentially look alike and there may be some production changes over the years that doesn't appear obvious to the end user. Locate the model number on the label on the side of the motor and call the folks at Fantastic Vent [800-521-0298]. I have found them incredibly helpful. They will confirm the proper size fuse for your model and will advise what steps to take to determine the cause of the blowing fuses if it continues with the correct size installed.
Mine also contain 4amp fuses from the factory. But DO check with FF with your particular model number.
-Rich-
Old 07-18-2013, 06:41 AM   #17
1964 26' Overlander
Toronto , Ontario
I second Seemore's comment about replying on cellphone. Shorts answers and spelling mistakes!
Anyhow, I checked this all out with Vintage Trailer. The final word: Fan-tastic vents use 4 AMP FUSES.
By the way, I never intended to overload my electrical system. Just wanted to know which fuse to use!
Thanks for everyone's help.
wigwag is offline   Reply With Quote
12v
