Old 01-06-2013, 10:38 AM   #1
StPierre's Avatar
1965 22' Safari
Rescue , California
Fan-Tastic fan
We are getting ready to install a new Fan-Tastic fan in our 65 Safari. Does anyone have any tips about installation, or had any problems that I should be aware of prior to the installation of the fan?
Thanks again for everyone's help on this project! We hope to have it complete by June....
St. Pierre
The St Pierre's
StPierre is offline   Reply With Quote
Old 01-06-2013, 11:10 AM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Don't use silicone caulk.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 01-06-2013, 11:16 AM   #3
1958 26' Overlander
Lander , Wyoming
Some of the main issues discussed with installation are whether or not to use the supplied gasket and potential cracking of the perimeter plastic part of the fan where the screws are inserted attaching it to the roof. I installed 3 fans on my 58. My solution/method was to not use the gasket but use plenty of trempro or sikaflex 221. Some have suggested using stainless washers above the plastic holes to help distribute the pressure. Be sure not to crank the screws down too tight. I used stainless screws and in addition to stainless washers used a strip of 18 g stainless sheet across each outer edge of screws. So from bottom up at each screw site I have: roof sheet; plenty of sikaflex; plastic fan edge ; stainless sheet strip; stainless washer and then stainless screw through it all. Hope that makes sense. I think it will help distribute screw pressure on the plastic edge and prevent cracking. Ed
n2batr is offline   Reply With Quote
Old 01-06-2013, 11:31 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Well.....I have installed seven of these fans in four different year model Airstreams...(including 2 in a 66.) I Used the Fantastic gaskets even though I felt apprehensive about the look and feel of them. I used Tempro 635 and stainless screws. I have never had a leak or other problem.
While you have the 14 x 14 opening exposed, run a 115v wiring and an ac drain line up there for future possible use.
Old 01-06-2013, 01:49 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You will have to cut the corners of the roof vent hole from round corners to square corners. Be careful not to cut into the wiring harness which is parallel to the roof vent.
Fantastik Fans are fine. But Maxx Fans won't let the rain in and can be left open on the road. Otherwise they are comparable.
Old 01-06-2013, 09:00 PM   #6
reinergirl's Avatar
Hollis , New Hampshire
I haven't done this yet but I'd be tempted to skip the tempro and use the method out lined here
http://www.airforums.com/forums/f456...day-86168.html
I used this tape to seal up an aluminum "thru the wall" doggie door and was extremely impressed with the product.
reinergirl is offline   Reply With Quote
Old 01-07-2013, 05:38 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I used Tempro on mine and no gasket and it has been fine for 3 years. I searched the forums before I installed mine and the discussion back then was the same, some pro some con on the gasket. The use of SS washers under pan head screws was advised by many and that is want I used. The flange can crack if you don't and if you use too much torque on the screws. I used an aluminum cutting wheel on a 4 inch grinder to square up the hole. Tape a garbage bag to the ceiling inside under the hole to catch all the crude that falls out. If you have not purchased the fan yet, spend a little extra and get the rain sensor option- well worth the money. Vintage Trailer Supply has them with a gray top and a curved bezel for the inside to match Airstreams lines.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-08-2013, 08:01 PM   #8
StPierre's Avatar
1965 22' Safari
Rescue , California
I have removeded the old vent without any trouble, and installed the new Fan-Tastic Fan. I have yet to seal and secure it to the trailer. I will post pictures when it is finished. Thanks everyone for your advice.
The St Pierre's
Old 01-15-2013, 08:52 PM   #9
StPierre's Avatar
1965 22' Safari
Rescue , California
I finished the fan installation without any problems. I am a bit disappointed with the amount of air flow, but it is far better than the original. I thought it would be more like a whole house fan, trailer size. Another project to check off the restoration list!
St. Pierre
ID:	176794   Click image for larger version
The St Pierre's
Old 01-15-2013, 08:59 PM   #10
richinny's Avatar
2011 34' Classic
it just feels like there isn't much airflow. close all but one window and you'll notice a strong flow by that window.
Ricky
Old 01-15-2013, 09:58 PM   #11
Tool Hoarder
West , California
I replaced both of my vent fans with Fantastic Fans. They fit the old holes perfectly. I used alot of Tempro and Stainless steel screws. I am thinkinh about useing butyl tape over the seams to water proof
ID:	176797   Click image for larger version
marzboy is offline   Reply With Quote
Old 01-16-2013, 05:50 AM   #12
2007 27' Safari FB SE
Pleasant Valley , New York
The ladder set up you have to get on top of the trailer for working looks interesting. Can you give more information as to what type and length of ladder you are using? Thanks!!!
bweybright is offline   Reply With Quote
Old 01-16-2013, 06:46 AM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
I use a similar ladder similar to a Little Giant. I glued a strip of carpet to the ladder rails where it may contact the skin with contact cement.
Old 01-16-2013, 09:56 AM   #14
Tool Hoarder
West , California
I actually am useing two 6ft scaffold platforms placed on each side of the trailer and my ladder bridged between.
