Old 12-17-2003, 06:08 PM   #1
newae's Avatar
1984 29' Sovereign
Riverview , Florida
Factory Work Info
I was wondering if anyone has had any dealings with the factory when it comes to repairs. I am thinking of taking my 1984 Sovereign to the factory for some work. Do you just make an appointment and drop it off? Do they do repairs rapidly? I would be coming from out of state and would want to stick around long enough to get the work done as long as it doesnt take weeks. I have e-mailed them but havent gotten a response yet. Any info would be appreciated.
newae is offline   Reply With Quote
Old 12-17-2003, 07:16 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Yep..
newae
To answer your concerns..
Normally, you'd be best advised to call ahead. Since this is the winter time, the "cheaper" rates are in effect and, they just might be booked up..You never really know until you call or show up.
I've had success in just showing up..As busy as they are, the guys at the service center always seem to be able to fit you in.
As for sticking around, there's a really nice campground on the factory's site that you can stay at (full hookup). They will bring your unit back out to the site each closing of the work day. You have to be up early and, ready for them to take it in each day to do the work.
If you've never been to Jackson Center, there's the factory tour, the town is small enough to walk around for a visit or, you can go out to the interstate head south to Wally's world...lol
The last time I was there, the charge was free (campsite) as long as you're having work done on your unit. I recalled this "free charge" extended to the day before and the day after of the work period. Otherwise, it was 10$ per night..(last years rate)
Good luck on your projects~
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-17-2003, 08:01 PM   #3
newae's Avatar
1984 29' Sovereign
Riverview , Florida
Thanks, I will take all into consideration. I havent had much luck locally on getting a few things repaired so I thought I might make a trip out of it and see what they could do.....
Old 12-17-2003, 10:23 PM   #4
newae's Avatar
1984 29' Sovereign
Riverview , Florida
What kind of work did you have done?
Old 12-17-2003, 10:58 PM   #5
1984 29' Sovereign
Savannah , Missouri
Thumbs up Alot~
You have to remember that this was spaced out over four years..And, not in the order that it was done.
  • I.Two new Fantastic Fans installed
    2.Four new wheels
    3.4 new shocks
    4.4 New brakes
    5.If they had the wheels off, the bearing were repacked
    6.New stainless steel stone guards
    7.New rear taillights
    8.New running lights all the way around.
    9.New skin panel installed over rear window.
    10.Auto on/off lights installed in pantry and closet.
    11.New univolter installed.
    12 New toilet, w/new ring seal.
This list doesn't include all the work I've done.(Which is rather extensive.)Such as stripping/polishing the Airstream. Sanded and repainted the A frame. Dropped the belly's skin on the rear and, sanded/repainted the rear bumper storage area. Sanded/repainted the water heater. Worked on the water pump.
Sealed all the windows. Rebuilt the bathroom vent blower motor.
Replaced one of the inner springs assy for the bedroom awning.
Installed new weather strippings where needed.
The next planned project is to remove the carpet and, install natural cork flooring thruout plus, replace the seal on front door and bathroom sewer vent pipe.
lol, I must have left something out but..I'm sure you get the picture. Just your typical things...
What kind of repairs are you in need of??
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 12-18-2003, 06:48 AM   #6
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
If you want to make appointments for Airstream, you can contacted them at the following number or e-mail addresses
Rick March (Service Coordinator)
rmarch@airstream.com
1-937-596-6111 Ext. 7406
Chris Burch (Service Advisor)
cburch@airstream.com
1-937-596-6111 Ext. 7413
Hours
7 am until 4 pm Monday thru Friday EST
Airstream web page
If you send e-mails to any other address for an appointment they have to be sent to these individuals.
December, January, and Feburary Airstream is running a special 10% of parts 15% off labor. I called and it sounds like December is booked. and there are still appointments for Jan. and Feb.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 12-18-2003, 03:16 PM   #7
newae's Avatar
1984 29' Sovereign
Riverview , Florida
I would like to have several leaks repaired (including one on a front window that I just cant seem to fix). I also need to have the cabinet over the stove repaired. The bottom has dry rot from years of the stove vent leaking. I would like to have them look it over good for other leaks and check the shocks, axles, etc. I also need a new fresh water tank. I have other issues I will check into depending on the expense of the above work.
Old 12-18-2003, 03:18 PM   #8
newae's Avatar
1984 29' Sovereign
Riverview , Florida
Thanks for the info JP. I may try for a Feburary appointment....
Old 12-18-2003, 03:18 PM   #9
1972 31' Sovereign
, Ohio
Images: 47
Has Airstream contacted you????
JP
Old 12-18-2003, 03:20 PM   #10
newae's Avatar
1984 29' Sovereign
Riverview , Florida
No, and it has been two days since I e-mailed them.
Old 12-18-2003, 03:22 PM   #11
1972 31' Sovereign
, Ohio
Images: 47
To what E-mail was it sent?
JP
Old 12-18-2003, 03:23 PM   #12
newae's Avatar
1984 29' Sovereign
Riverview , Florida
tech@airstream.com. I got the e-mail address from their web site.
Old 12-18-2003, 03:26 PM   #13
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Newae,
Having just come from Jackson Center, I can say first hand that everyone there is running all around with tons to do and not a lot of hours to do it.....I'm sure they will contact you soon. Have you followed up that email with a call to either of the phone numbers for Rick or Chris?
One other thing that I'd like to share is that the work done by the service department there is really top notch...just ask jodynjeep!
Eric
PS- jpairstream posted alternate email addresses for both folk in the service department than the tech one.....
Old 12-18-2003, 03:26 PM   #14
newae's Avatar
1984 29' Sovereign
Riverview , Florida
What work have you had done JP?
