Old 09-19-2016, 12:22 PM   #1
2016 28' Flying Cloud
Queensbury , New York
Factory door adjustment ???
I have a 2016 FC 28W . The entry door seems to be somewhat out of adjustment.
I had the dealer adjust it about a month after we got it. They centered the door pin on the lockset. It is better but still seems like something is binding.
When you open it , it pops open about and inch and stays there. I need to give it a good stiff arm to close .
I always make sure the trailer is level and only use the stabilizer jacks for there purpose . Not to tight !
I am about a 1300 mile round trip from the factory and don't mind going there if they can improve it.
Question is ,
Are these doors like this or can they be fixed ?
MOS is offline   Reply With Quote
Old 09-19-2016, 12:39 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is not common. If the door "Pops Open"that says there is a preload on the hinge or gasket at the hinge side of the door. If left unattended it could cause metal failure somewhere around the hinge
The trailer should be under warrant if it is a 2016. Call JC and ask for a knowledgeable place closer to home or a factory rep to come out.
2004 Excursion 4x4
Old 09-19-2016, 12:44 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Have you tried lubrication? That is all I had to do when mine got a little hard to close.
SeaLevel is offline   Reply With Quote
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Door Latch Adjustment moosetags Doors & Locks 14 03-23-2012 03:48 PM
Door adjustment HowieE Exterior Restoration Forum 18 10-01-2009 08:24 PM
Toilet trap door/slide adjustment grannyred Sinks, Showers & Toilets 0 11-30-2006 04:40 PM
Door Hinge Adjustment Cracker Doors & Locks 11 11-02-2003 07:24 AM
