Old 04-18-2014, 10:54 PM   #1
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Extra Fuses
We are contemplating our first long outing with our new AS, knowing me I will probably blow a fuse or two and the wrong time of day/night. My question is what type and amount of extra fuses should I have in my tool bag? Is my answer in the owners manual, or trial and error? Appreciate the assistance.
Luigi123 is offline   Reply With Quote
Old 04-19-2014, 03:51 AM   #2
ottawa (greely) , Ontario
First of all I have never blown a fuse during a trip but if you open your fuse box you will see the type of fuse used, mine uses automotive 12 volt fuses ato 5, 10, 15,20, 25,30 amp fuses you can get assortment pack in some cases your tow vehicle has (spares ) the same, but newer tv are now using smaller size ( mini)or mini low profile size fuses, and your trailer will have circuit breakers for 120volt ac plugs , just remember if you blow a 12 volt fuse there is a problem ! They are there to protect the wiring agains shorts and over loads, so on 12 volt system you should never burn a fuse for over load unless someone added a load to a circuit after the trailer left the factory, but can burn a fuse for short circuit(were a wire rubbed through insulation to ground) or water in sockets etc. on the 120 volt circuits you can easily over load a circuit and trip a breaker as in the case , toaster(12 amps)used at the same time as kettle (12amps) on same circuit as most circuits can only handle 15 amps So if you add the load of the toaster and kettle they equal 24 amps and that's too much for the 15 amp circuit so the breaker trips ,all you have to do is reset the breaker if it happens ,
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 04-19-2014, 07:23 AM   #3
2014 25' FB International
Chesapeake , Virginia
If your luck is like mine the fuse will blow at the worst time and no place to buy a new one. I purchased an assortment of fuses from Walmart in a small plastic case that included a fuse tester. The cost was around $13.00.
Chip2013 is offline   Reply With Quote
Old 04-19-2014, 07:49 AM   #4
Luigi123's Avatar
Thanks Scamp and Chip. Will stop at our Auto store today.
Old 04-19-2014, 08:16 AM   #5
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
A pack of 15 amp plug in fuses for most things and 30 amp in line for the hitch jack. Then a pack of assorted plug in fuses just in case. The only fuses I've ever blown were the 15 amps.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 04-19-2014, 12:24 PM   #6
richw46's Avatar
Lexington , Kentucky
If you have an inverter you will have overload fuses in there too. PO blew out the two 35 amp ATO fuses and I had a hard time finding replacements, had to order online. (Locals had 15, 20, 25, 30, 40 and 45 but no 35.) There may also be auto resets in some equipment. Disconnect from the power source, wait a minute or two, then plug back in to see if it resets.
The most important thing is to know the proper size. My 2004 TV uses the ATM (mini) but the 2006 AS uses ATO (standard). Like Scamp said, open your fuse box and see what size you have, then buy a kit of the different values.
In a pinch you can borrow a fuse from a different circuit but never go above the blown value. You can substitute a 30 amp for a 35 amp but never go up in value; dangerous.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-02-2017, 09:08 AM   #7
2017 22' Sport
Monteagle , Tennessee
Using Generators
New in the community and have a question about generators and their use. When using a generator do I use the 30 amp plug or the 15/30amp outlet to energize the trailer system? I know not to use 220amp service. Thanks in advanced.
Paul
2017 22 Sport
Paul1031 is offline   Reply With Quote
Old 01-02-2017, 09:37 AM   #8
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
Paul
2017 22 Sport
You can use either, but if generator has twist lock 30amp I would use it.
1973Argosy is offline   Reply With Quote
Old 01-02-2017, 09:46 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What kind of generator?
Old 01-02-2017, 09:59 AM   #10
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I've since blown a 2 amp mini on the water heater (by tightening the plug while the heater was on and touching a wire with the wrench) and I see the fantastic fan takes a 4 amp.
Antique Pedaler
Old 04-15-2017, 09:29 PM   #11
2017 30' International
Lincolnwood , Illinois
does the 2017 international use mini or regular fuses or some other size?
Milo1952 is offline   Reply With Quote
Old 04-15-2017, 09:46 PM   #12
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
The 30 amp in line for the hitch jack
The 30 amp hitch jack fuse is very easy to blow if you try to raise the hitch jack too high. I was at a campground in Sioux Falls, S.D. when this happened to me. I was planning on leaving out early the next morning so I was hitching up the trailer when the fuse blew. Thanks to a fellow camper I did not have to try to manually let the hitch down because he took the fuse out of his hitch and let me use it. First stop the next morning was at a Napa Auto Parts Store. I bought a six pack of 30 amp fuses and keep them in the tow vehicle now.
Silverbee is offline   Reply With Quote
Old 04-16-2017, 09:56 AM   #13
richw46's Avatar
If you know that there isn't any short circuit and the fuse was blown by accident, you can use a very light straight jumper wire instead of a fuse, if you have no replacement available. If there is a dead short, the jumper will quickly melt. If not a short, you're out of a tight spot.
On my old outboard there was an inline 15 amp fuse that blew. I was several miles away from the dock and had no spares. I didn't know what caused it but I had my wife and kids with me, I needed to get back to the dock.
I was smoking at that time and I took some foil from the pack and wrapped the fuse in it. The motor started and we made it back. I found the short and repaired it.
-Rich
Rich & Yvonne
2004 4Runner SE
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
40 amp fuses for Univolt java71 Electrical - Systems, Generators, Batteries & Solar 9 06-24-2005 04:31 AM
40A Fuses? 66Overlander Electrical - Systems, Generators, Batteries & Solar 2 04-22-2004 08:07 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
12 volt fuses jim clydesdale Electrical - Systems, Generators, Batteries & Solar 2 03-18-2003 05:47 PM
