I was thinking on a "condenser" cooling fan it would work better on the top of the coils at top of cooling unit call the condenser coil. One reason I believe the new AS have issues with cooling in hotter climates is the lack of a roof top vent.
It seem the new or some of the newer unit have vent on bottom and up the side walls vs out roof vent. The fan mounted in bottom vent is akin to peeing in the pool. It warm around you but the overall temp of the pool is unchanged.
I have watched video of RV refrigerators with condenser fans that have t-stats attached to the line just past the condenser coils that would turn on if the liquid in coils were not getting cooled enough to allow the unit to effectively run.
When the refrigerator was not able to cool like normal, it was determined the fans were not turning on like they were doing before and the fans or what ever the problem was determined to be was fixed.. Most of the time the problem is the fan quite working in hot weather conditions.
SO to bring this all back to the point the fan or fans need to be on top of condenser coils to move more air across the coils to help with the process of cooling the liquid in the system at that point.
If you read up on how a RV ammonia system works you see the need for more air at the condenser coil if possible.
most of the time the fan are sitting above the top coil you see in teh picture below as that is the condenser coil.
picture taken from article in "Highways" Aug/Sept 2012 by Gary Bunzer, the RV doctor.
(picture taking hit for all.. first pic took with camera in normal talking position aka up and down.. second pic taken with phone turned on side like TV screen. posting here likes sideway taken pic to show up correctly..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691,
Piedmont Airstream Club, Unit #161, Region #3
