Old 07-13-2017, 04:48 PM   #15
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Thread re my install post 711 Note there is discussion re wiring ID
http://www.airforums.com/forums/f542...ml#post1774433
Post # 10 This is a past post of mine that contains my experience as well as the link to the mother of all refer fan & noise threads
http://www.airforums.com/forums/f425...ml#post1937288
post # 18
Lastly a recent thread re a dual fan install (nice work and results)
http://www.airforums.com/forums/f425...ml#post1966148
this quiet design from jukeboxfun post #35 and this simple and effective solution post
# 11 by silvergate
http://www.airforums.com/forums/f425...ml#post1919845
don;t underestimate sivergate's solution. It is amazing how much is helps the flow and allows the fan to cycle off earlier, this reducing wear and tear.
CruizinDux is offline   Reply With Quote
Old 07-13-2017, 04:56 PM   #16
CruizinDux's Avatar
Originally Posted by CruizinDux View Post
Not sure of the color but function is correct. I'll look for some past posts
Copper wire is +, middle silver wire is - and odd man out RPM control.
hmmmm.....Better double check. Re-reading my install post in the 1st link above " Lastly the wiring was pretty easy. As others have posted the image, hot is the center of the three. Looking at the plug converter it was pretty easy to determine which line was to be was abandoned (third wire odd man out…RPM control?). I clipped this short for easier ID, then slipped it in the shrink tubing to keep it out of the way. I did test on the batt to confirm the + / - and also before I soldered via fan switch, but the install was a no brainer."
Usually hot is copper and ground/common is silver. My apologies for the confusion. Try it on the TV's battery first to confirm. The fan label is the exterior side so air should be flowing out from the label.
IMO two fans is overkill. Loose the OEM and get a quality quiet fan. I went with the thicker model and the air flow specs were a bit better.
Old 07-13-2017, 05:02 PM   #17
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
If you do not want to mess with electrical, I would recommend looking at a solar exhaust fan cover that would replace the existing rooftop vent. They are for sale on Amazon for about $80. Its only gonna run in daytime but that's when cooling is mostly needed in the heat of the day for your frig.
They also have another solar exhaust fan for the black water vent pipe on the roof. Very simple to install and no wiring needed.
Mike1997 is offline   Reply With Quote
Old 07-13-2017, 05:42 PM   #18
Bathurst , New Brunswick
fridge fan
Originally Posted by greghoro View Post
The refrigerator fans do not work constantly, only when the refrigerator needs their assistance. It could be during the time their assistance was not needed that you found your new fans would not work.
This solution is only good when you have shore power. More flexible to use a 12V fan.
Greg
Hi I just moved my fridge location in my vintage rebuild and needed an exhaust. So i put in an aluminum stack and piped it to the top , back of the fridge. Just used a good computer fan and added a furnace plenum fan control. On at 120f off at 100f.
Bimetal control,so no power needed. See attached pics
ID:	289433   Click image for larger version
ID:	289435   Click image for larger version
mrfixit51 is offline   Reply With Quote
Old 07-13-2017, 05:52 PM   #19
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
These are the fans we used in our 23D to cool the refrigerator compartment with positive air flow from bottom to top and thus the refrigerator ran cooler.
The fans were on a manual lighted switch when the stock Dometic refrigerator was in the trailer. After we upgraded to a freon based Vitrifrigo refrigerator with a 12Vdc DanFoss compressor, the fans come on whenever the compressor is running.
Name:	23D Fridge Cooling fan new inside view-1.jpg
ID:	289437   Click image for larger version
Name:	23D Fridge Cooling fan new outside view-1.jpg
Old 07-13-2017, 10:18 PM   #20
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Here is a 12v fridge fan with a thermostat: https://accessories.lazydays.com/val...FQKewAode_AFlg
Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 07-15-2017, 09:30 AM   #21
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
here is what I did, modeled after Switz's, modified. My install did not require removing the firdge. Feel free to PM if you have specific questions:
http://www.airforums.com/forums/f425...ds-166096.html
Troutboy
Troutboy is offline   Reply With Quote
Old 07-15-2017, 11:18 AM   #22
2006 19' Safari
East Greenbush , New York
What I did, years ago, was to buy a Snyder's rv fan kit. Sadly, no longer in business.
It's a molded trough of plastic which fits around the bottom and sides of the coils. There is a temperature-activated fan at the bottom of the trough. It forcibly sucks air over the coils.
I've never had troubles with a warm fridge since it's been installed.
The secret seems to forcibly pull air over the coils.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
heitkergm is offline   Reply With Quote
Old 07-15-2017, 09:36 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We mounted 2 sealed pc fans to an aluminum frame we made. It was mounted so that it pushed air vertically, so it moves air without pressuring the space. The performance has been great as we were able to freeze water as well as keep things frozen in 106 degree weather.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-16-2017, 12:51 AM   #24
switz's Avatar
2014 31' Classic
Images: 8
In our 2015 23D, there is a ceiling in the refrigerator compartment just an inch or so above the top vent opening because the convection microwave support is the other side of the ceiling.
If the propane oven were a convection microwave, then a taller refrigerator could be installed with a caveat that the side top vent would also have to be raised so there would not be a really dead air space where exhaust fumes could accumulate above the existing cent level.
Old 07-17-2017, 06:25 AM   #25
Goingcamping's Avatar
2017 16' Sport
Cherry Log , Georgia
Plug In 110v fan
Originally Posted by harryk View Post
I bought a small 110v fan at walmart and plug it into a receptacle mounted above the refrig. access door...fan has a switch, off, low, & high. I turn it on only when its hot out...its pointed up toward the roof vent. Works fine.
None of the ones I have seen at Walmart fit or are hard wired. Would you mind sending a pic of the fan you purchased? Many thanks!
Goingcamping is offline   Reply With Quote
Old 07-17-2017, 12:24 PM   #26
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Last March, while at the Escapade in Tucson, I had the ARP v.2 module installed in my '87 Excella. Last month one of my friends who has a SOB and has experienced rv refrigerator failure installed the ARP v.3.1 module with the fan. Their website https://www.arprv.com/ is very informative, and Paul & Mao Mack, the engineers who designed and market this product, will answer any questions. Briefly, the module monitors the boiler temperature of the refrigerator and prevents the boiler from overheating, very often due to being parked off level.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 09-05-2017, 10:20 PM   #27
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Originally Posted by vintagemotor View Post
Mattirs,
Most computer fans will have a "trigger" wire, thus the 3 or more wire harness on the fan. I cut off the connector and strip back a small portion of the wires, connect 2 of the wires together and test with a battery to find out which ones will spin the fan blades the correct direction (reverse polarity = reverse spin).
I chose red led fans which have an extra wire for the led lights, so 2 wires to neg and 2 wires to pos, it only took a couple seconds to figure out which.
Install 2, 3 or 4 fans, it doesn't matter as the fans use such a little amount of power (thus the tiny wires), just wire them in parallel, all positives to pos and all negatives to neg.
Good luck!
I finally got the fan to work the other day, had other pressing matters and I needed to step away from the situation to see what I was doing wrong.
I was attaching the negative to one side of the thermal coupler and the positive to the other side of it. Guess what when you do that there is no power flowing through it. DOPE SLAP!
Now that I run power through the fan it works.... as in connect the positive to the wire running to the coupler and the negative to the coupler it's self. Again Dope Slap. LOL
Now I have two quieter fans moving more air.
Matti
Mattirs is offline   Reply With Quote
Old 10-08-2017, 06:02 PM   #28
Mattirs's Avatar
I think I need a bigger fan
Found a fan on sale that moves a 3rd more air at a third less power and is so quiet I can barely hear it outside of the grill. It was all but silent when I had the air blowing inward, now what I hear is the air blowing across the screen and grill.
When I first installed it the air blow inward, but friend of mine who works in heat transfer told me it is better to have it pull the air out of the box. I tried reversing the wires but the fan would not run so I had to turn the fan around.
It is a 240 X 240 computer fan, I ended up leaving the bracket where it was and drilled new holes. Used an old flip flop to use and padding and sound transfer insulation.
Did a test run cooling the frig overnight and it cooled faster then again the weather was cooler.
Matti
Name:	New Frig Fan 20171008.jpg
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 06:34 PM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Extra wires to fridge? danjoe91 General Repair Forum 7 07-18-2013 10:30 AM
Thermostat for behind the fridge fan? blickcd Refrigerators 6 08-10-2010 09:22 AM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
