Old 07-25-2012, 05:43 PM   #1
1964 22' Safari
Homosassa Springs , Florida
exterior suicide door is bent
How do I reform it? 1964 Safari door opens to become suiside screen door which is also bent.
Auhe is offline   Reply With Quote
Old 07-25-2012, 05:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That door is cast aluminum. If it's bent, it's probably broken.
Old 07-25-2012, 06:45 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
My trailer is a bit newer so it is not a cast frame but this is what I had to do.
I cut a bow approximately the curve of the door and clamped it to the bow. after each clamping I would add about 3/8 material to the form and shave it to zero at each end. Reclamp and check. I had to add about 5 pieces to the original form before the door came back into the frame.
Not sure a cast door frame will take this method but the secret is to take it in small increment.
The picture show the form as first cut while I figured just how to place the clamps.
2004 Excursion 4x4
Old 07-25-2012, 07:51 PM   #4
Central , Mississippi
Perhaps you are lucky and your '64 has a leftover frame from '63...mine does not have a cast frame, simply a bunch of flat stock formed to the shape and skinned on each side.
If that is the case, try Howie's method. If it gives you a hard time, remove the inner skin, bend the door to shape and reinstall the skin.
I've never messed with a cast frame but understand they are a bit fragile...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
