03-13-2012, 09:24 PM
2014 23' International
Saint louis
, Missouri
Exterior strip coming off - suggestions for adhesive?
Hi all,
There is a strip coming off Roameo - see the attached photo. I've used all the skill I have to reattach see duct tape. Does anyone have suggestions for adhering this. I believe the hubby did try some adhesive but after winter storage we found it hanging off again.
Thanks for help
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
03-13-2012, 09:53 PM
Ottawa
, ON
I believe that there is usually a sort of clip that is held on by a screw (or is it a rivet) that has a little step built into it. But it's been 5 months since I last saw my trailer so I won't swear to it.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
03-13-2012, 10:13 PM
2008 27' Classic FB
Burkburnett
On the newer trailers, this is held on only by a peel and stick adhesive strip on the back. Is seems that moisture and dirt can gain a foothold starting near an end, usually near the front, probably from road spray and wind. I lost one completely off the stone shield. Inland sells it by the foot, so far it's holding. I believe Andy at Inland recommends 3M Weatherstrip Adhesive in addition to the adhesive strip. The surfaces should be cleaned with alcohol for best results. Was surprised that the ends aren't secured mechanically to prevent this from happening. Maybe a pop rivet or a stainless sheet metal screw, but I'm not too keen on adding any more holes that might leak water to the interior.
AIR 47751
03-13-2012, 10:32 PM
2007 23' Safari SE
San Diego
03-13-2012, 10:54 PM
Salem
, Oregon
Hi, use 3-M body side moulding tape; It is either black or dark gray in color and wrapped in red plastic. Do not use the 3-M household tape that is white in color and wrapped in green.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
03-19-2012, 10:05 AM
2006 25' Safari
St. Augustine
Yep, just replaced all of my chrome insert. It is 3M sticky on the back side (stuck on via tape) The directions say to clean the area thoroughly with isopropol alchohol before adhering. That may help in your prepping the area. The rail itself is held on my trailer by both rivets and screws. I would think that RobertSunrus' solution would work for you.
03-19-2012, 10:22 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I suggest cleaning the aluminum with 3M Adhesive Cleaner and reattaching the plastic insert with 3M weatherstrip adhesive. I prefer the black adhesive from 3M. They make a yellow color, too.
Both products available at a good auto parts store.
This worked for us.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
03-21-2012, 06:51 PM
Saint louis
, Missouri
Thanks All!
Here's me with the tape - turns out we had to get three rolls. Two so we could line them up along the strip - the third because we couldn't find the second until of course after we bought the third!
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
03-21-2012, 07:31 PM
2006 19' Safari SE
Tucson
That's similar to what we used, too..I think ours was labled "exterior super strength" or something like that. It fit the track perfectly and our silver molding isn't going ANYwhere now!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
