Old 10-15-2015, 03:34 PM   #1
slimhawg's Avatar
Sunrise , Sunset
Exterior rivet size?
On 2013 27FB, one of the three brackets that the rock guard bolts to snapped all four rivets. Does anyone know what size these are? Also, I assume when reattaching the bracket there should be some sealer (silicon) between the bracket and the surface of the trailer??
slimhawg is offline   Reply With Quote
Old 10-15-2015, 07:14 PM   #2
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Here's a great video posted by TheSignLady here on Air Forums, which may help.
Rocinante is our 2014 International Signature 27FB
Old 10-16-2015, 08:57 AM   #3
slimhawg's Avatar
Sunrise , Sunset
That is a good video. The rock guard brackets (as it turns out) have 1/8 x 3/16 pop rivets. Unfortunately, my bracket pulled the rivets out so the holes are bigger now. Thanks though.
Old 10-16-2015, 12:08 PM   #4
Rivet Slave
Rocinante's Avatar
Sorry about the enlarged rivet holes, here's hoping you can find a rivet size or other approach that will do the trick!
On the sealant front, the one thing I've gathered from all the threads here is that silicon is not to be used on an Airstream's aluminum skin, inside or out. There is a range of others that can be useful, but silicon is not generally one of them.
Good ones we've heard mentioned here include:
* Par Bond (here's an example): http://www.amazon.com/dp/B007HRX62S)
* Trempro 635 (modern Vulkem, it says here): TremPro 635 sealant)
* Captain Tolley's Creeping Crack Cure: Captain Tolley's Creeping Crack Cure
To make matters more confusing, there's apparently one exception to the no silicon rule. This link explains what kind of silicon sealant it is and when to use it: TremPro 644 RTV Silicone Gray Aluminum
Oh and full disclosure: We're not super handy over here at Casa Rocinante - we're just doing the best we can, and often resort to our dealer for support. There are others on the forum who have pretty much taken their trailers completely apart and put them back together again in better-than-new condition, so hopefully a couple of those folks will chime in.
Old 10-16-2015, 06:08 PM   #5
Rivet Slave
Rocinante's Avatar
Forgot one: Sikaflex 221. Here's one example in gray, though I suspect you can get it cheaper. Comes in white, black, gray, and maybe other colors: Amazon.com: Sealant, Gray: Automotive
Here's a sealant thread in case you want to read more: http://www.airforums.com/forums/f44/...ry-116214.html
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 09:29 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 04:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
