Old 05-19-2014, 07:44 AM   #1
1971 31' Sovereign
Dalhart , Texas
Exterior locks
Hi, We acquired a 70/71 Land Yacht recently that needs a lot of work so I have been looking over all of the excellent posts on this site. I will probably be on here a lot once I get started on the restoration but my first question is this: Is there a place you can send the locks to and get new keys made? All of the locks are in place and look to be in good condition but the PO cannot locate the key. I would really like to keep the original and not have to drill out the old.
Thanks in advance for your help and advice.
Donny P is offline   Reply With Quote
Old 05-19-2014, 07:50 AM   #2
To be safe, post a photo of the locks that you need keys for.
Also, the trailer serial number spells out what year as different years use different keys.
Once you post that info, then you have a good fighting chance for the keys.
Old 05-19-2014, 08:13 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Any lock shop can do that work for you. I did it and it took the locksmith less than 15 minutes for the main door and replace the compartment door.
Old 05-19-2014, 10:12 AM   #4
1971 31' Sovereign
Dalhart , Texas
Pic of lock
Old 05-19-2014, 11:43 AM   #5
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
As a former locksmith, I can second melody Ranch's suggestion: a locksmith can make a key for the lock(s), usually by the impression method.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 05-20-2014, 02:43 PM   #6
1971 31' Sovereign
Dalhart , Texas
One more question, should I expect the key for the entry door to be the same or different from the access doors? If different, are all the access panel doors keyed differently? Thank you
Old 05-20-2014, 03:30 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Donny, the entry door key is different for each trailer.
The baggage, water fill, and battery door locks use standard keys that are the same for all Airstreams, aside from production changes every few years and slight differences between models.
Old 05-22-2014, 05:43 AM   #8
1971 31' Sovereign
Dalhart , Texas
Thanks for the information guys, I really do appreciate it.
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Wheel Locks, coupler locks Toasty's Dad Hitches, Couplers & Balls 10 03-06-2008 11:55 PM
source for exterior compartment door locks? stinky_hermi Doors & Locks 2 04-19-2007 05:23 PM
Exterior Compartment Locks. Navigator Exterior Storage Compartments & Access Doors 12 03-10-2006 11:05 PM
Door Locks on older MH thenewkid64 Airstream Motorhome Forums 3 03-05-2002 06:27 AM
