Old 01-18-2019, 11:47 AM   #1
2005 22' International CCD
Camarillo , California
Exterior Light for Entry Steps
I would like to install a light under my AS that would highlight the entry steps. When exiting my AS at night the steps are very hard to see.
I have purchased a 12v LED light that will fit under the AS that will light up my steps at night. My plan is to tie into the wiring/switch that operates the exterior light over the door. Has anyone else done such a thing? Does anyone have a problem seeing the steps at night? Thanks
MarkBeck is offline   Reply With Quote
Old 01-18-2019, 01:18 PM   #2
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Yes; I installed a marine underwater blue light to light the steps, connected to the exterior door light.
Steamy1 is offline   Reply With Quote
Old 01-19-2019, 01:03 PM   #3
Thank you. I'll take a look online for a marine light and see if I'd prefer that over what I have. I have a cabinet on the back side of the exterior light switch just inside the AS that I can use for access to the door light switch. Is that what you did as well?
Old 01-23-2019, 09:40 AM   #4
Hello,
I removed the aluminum interior door threshold piece and drilled a hole in the floor. threaded the wires up through the hole, sealed and mounted the light above the step. Then ran the wire along the door edge, re-installed the threshold. worked the wires in between the cabinet edge and the wall of the trailer up to the switch. Connected the wire to the overheard exterior door switch.
I like the blue light as it is soft and does not glare.
Entry steps Shiloh4570 General Repair Forum 1 01-09-2015 10:14 PM
Entry steps on '77 Argosy motorhome WineStream Argosy Motorhomes 5 09-09-2013 12:16 AM
Any suggestions on rugs that will fit the entry way steps? barrettjl Windows, Doors, Locks & Vents 5 07-08-2012 07:49 AM
Entry steps for '75 Argosy 24 1Michigander Repairing/Replacing Floor &/or Frame 24 04-01-2012 08:50 AM
