Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-17-2008, 09:03 PM   #1
Rob&Julie
Profile:  1988 32' Excella
St. George , New Brunswick
Expandable Foam Insulation???
Has anyone heard of/tried expandable vapor barrier foam as an insulation upgrade?
I'm thinking of the blue stuff that you would use in your home....not the crack filler but the commercially applied stuff. It supposedly has an r value of 20-24 per inch and it's waterproof. You would have to shave it down level with the ribs if it was too thick.....
My first negative thought would be how do you remove it IF necessary in the future.
Thoughts.....??
Rob
Rob&Julie is offline   Reply With Quote
Old 05-17-2008, 09:36 PM   #2
jayray5
Profile:  1973 25' Tradewind
Romulus , New York
When expanding and curing the foam generates a good deal of heat. It may interfere with the expansion and contraction of the skin as well.
jayray5 is offline   Reply With Quote
Old 05-17-2008, 09:47 PM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Hi Rob, if you do a search you should be able to find some threads on this. It seems that the general feeling is that along with the problem you mention, there is a lot of movement that would break the foam down over time, leaving you with some amount of dust in your walls.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-17-2008, 09:52 PM   #4
Fyrzowt
Fyrzowt's Avatar
Images: 8
Here are a couple of threads to get you started reading...
Foam Insulation? 69 Caravel
Insulation effectiveness tests
Insulation - real test results...
AIR #15800
2000 Safari SS 25'
Old 05-18-2008, 12:06 PM   #5
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
I just got called over to a new friend's 60's Airstream for a look-see and someone had done the entire belly frame-floor area with sprayed on foam insulation.
I don't know if it was done in 1977 or 1997 - it had not disintegrated but with tupperware precision had held every bit of moisture it could against the wood and steel; shielded dry-rot safely away from any air circulation, wicked bathroom leaks quite offensively, and effectively sabotaged the thought of any painless access or repairs beneath the belly skins untill the day Joe-Somewhen does a shell-off floor replacement and complete sand blast of the frame.
On thinking long and hard on it I don't see a way to accommodate spray-in-foam with Airstream construction for all LONG TERM considerations and compromises....
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Spray Foam Insulation Question Gkiesel General Repair Forum 3 04-08-2008 02:08 PM
Foam Insulation? 69 Caravel Maximo General Repair Forum 3 03-02-2008 08:42 PM
Spray polyurethane foam insulation sfixx Exterior Restoration Forum 47 02-20-2007 12:54 PM
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 09:19 AM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 09:39 PM
