Old 03-23-2015, 10:08 AM   #1
jvcolaizzi's Avatar
2016 30' Classic
Park City, Utah , Utah
Excella Fresh Water Tank Drain Plug??
1983 27ft Excella....looking for fresh water tank drain valve. Help!!
jvcolaizzi is offline   Reply With Quote
Old 03-23-2015, 11:44 AM   #2
1986 31' Sovereign
Miami , Florida
Should be between the tires on the curb side.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-23-2015, 12:01 PM   #3
2000 30' Excella
Toledo , Ohio
Mine is on the road side between the tires
woodfox45 is offline   Reply With Quote
Old 03-23-2015, 12:03 PM   #4
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Between the tires curbside.
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 03-23-2015, 12:54 PM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Curbside behind forward tire. Between the tires as stated prior. Little awkward to get to thanks to the engineers at AS.
5 years ago, I attempted to drain my fresh water tank by trying to move the handle on the valve, well the handle broke off in me hand. Luckily the valve remained closed. 2nd Picture shows missing broken handle. I eventually replaced the valve and sealed some leaks. I have additional pictures as to what it looks like in the access panel under the valve if you need to see them for any reason, just let me know. To gain access to replace and repair inside that area I had to cut up the side of the tank protector where the valve is.
ID:	234806   Click image for larger version
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-02-2015, 09:07 AM   #6
1989 25' Excella
Albemarle , North Carolina
fresh water drains
My owner's manual for 25" Excella shows 2 drain plugs underneath slide out pantry. Pantry only slides out half way and is completely enclosed. Any idea how to get that slide out pantry OUT to get to the two plugs? If you can help .. could you please reply by email: Marti2Ray@vnet.net thanks
eldin is offline   Reply With Quote
Old 04-02-2015, 09:40 AM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Doesn't seem right... A drain plug inside the trailer inside the pantry would be on top of the fresh water tank, not too effective for draining.
Look outside underneath your trailer.
John
John & Vicki
WBCCI #4291
Old 04-02-2015, 09:47 AM   #8
Venice , Florida
Images: 14
Look at Post # 5. Tells the story. My manual says something different also.
Airdreamers
WBCCI #8880
AIR #41310
Old 07-24-2015, 06:08 AM   #9
Beverly Hills , California
Ran into the same issue on my new(er)-to-me trailer and got a quick lesson from the lead tech at Jackson Center.
For the travel trailers, the fresh water drain almost all of the time is on the same side as the fresh water fill. So, if the fresh water fill is on the street side, the drain valve (if it still exists and was not yanked off or removed) is most likely somewhere in the wheel well on the street side. Actual location of the drain valve within the wheel well (forward, between, aft) does seem variable.
This seems like it is referring to draining the interior water lines versus the holding tank valve (per the OP's question). And yes, they are in many different locations. While far from an expert in this area, I have observed that the interior line drains do poke out of the belly, so take a look at the underside for a pair of tubes a few inches apart, and the valves are directly above. In terms of accessing the valves from inside the rig, chances are good they are easily accessible (presuming good personal flexibility) through a hatch / door once you know where they are.
JayTheCPA is offline   Reply With Quote
fresh tank drain plug has bad threads excellaf350 Fresh Water Systems 0 07-05-2013 07:32 PM
Adding a drain plug to fresh water tank... bambid General Repair Forum 3 05-06-2012 07:06 AM
Where is the fresh water drain plug located? bambid Fresh Water Systems 10 06-24-2010 08:47 PM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Tool to remove fresh water drain plug willbrackman Fresh Water Systems 5 06-19-2009 10:44 PM
