Old 10-10-2014, 12:21 PM   #1
2015 25' FB Flying Cloud
Charlotte , North Carolina
European Cabinet Hinges
The European style cabinet hinges on our new Flying Cloud have repeatedly separated while underway. The hinges have a trigger on the end which, when pressed, cause the hinge to separate. Any moveable object in the cabinet is capable of activating the trigger. Any suggestions on eliminating this annoyance?
MaiziesGang is offline   Reply With Quote
Old 10-10-2014, 12:26 PM   #2
dznf0g's Avatar
Oswego , Illinois
Picture? Can you get to the back side of the trigger and put a piece of hard foam rubber under it?
-Rich-
Old 10-10-2014, 01:40 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
You are still under warranty, I would take it back to the dealer and make them "make it right." It could be that you particular batch of hinges is bad.
Bob Martel
WBCCI# 5766
Old 10-10-2014, 01:42 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Hinges separating? Has there actually been more than one? Reason I ask is that I've had to take these hinges apart several times and I've had a heck of a time getting them open. Hard to picture them coming apart simply by being hit by something while traveling. Possibly a defective hinge or one not snapped together tight to begin with?
Al - K4GLU is offline   Reply With Quote
Old 10-10-2014, 01:51 PM   #5
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
This has happened in ours a couple of times. I'm not sure there is anything that can be done......that's just how the hinges work. We have the European hinges in our house and occasionally they come apart as well.
Landrum is offline   Reply With Quote
Old 10-10-2014, 01:53 PM   #6
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Those hinges have adjusting screws that too often loosen making the doors jam or get lopsided.
Seems that using them on a moving, bouncing RV is not a best idea.
They work well with household cabinets and are easier for the cabinetmaker to install and to adjust. But not in an RV, as they can be a pain for the average person to fix and adjust the doors.
JStanley is offline   Reply With Quote
Old 10-10-2014, 02:08 PM   #7
Yes they are a pain to adjust - I've been down that road several times. But I've never had one come completely apart on its own and I've towed 3 Airstreams several hundred
thousand miles in the past 8 years.
Old 10-10-2014, 03:25 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
As a cabinetmaker who uses these hinges everyday, I find adjusting Blum hinges to be very easy. Up and down is the screw on the base plate that the hinge attaches too. In and out is the very back screw in the hinge itself, and the side to side adjustment is the screw closest to the door.
I'm very surprised that these hinges are coming apart so I suspect the quality of the hinge maybe at play. Blum make a great hinge with a very positive catch system. Yes, it still has a trigger release at the back of the hinge but the tension required to release is pretty high so an accidental release would almost be impossible.
You could probably replace the existing hinges with Blum or Hafele hinges easily as they all use the same 35mm hole mounting system.
Cheers
Tony
Old 10-10-2014, 03:35 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I find it particularly annoying in the cabinets under the bed. With is where I store heavy stuff- like a plastic tub full of dog food. I can't seem to remember to pick the tub up high enough to clear the release lever that makes the hinge come apart. It's easy enough to pop it back together, but annoying. Especially since on the front bins they use ordinary hinges.
2012 Dodge Durango Hemi/AWD
Old 10-10-2014, 03:48 PM   #10
Landrum's Avatar
That's what happens with me.....I hit the back of the hinge with something heavy which causes the release.
Old 10-10-2014, 03:58 PM   #11
Three doors have come off, one twice.
Old 10-10-2014, 05:35 PM   #12
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
There are cheap euro hinges out there.
Look to see if they are marked BLUM
If not replace with BLUM hinges.They are high quality.
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Old 10-10-2014, 05:47 PM   #13
1981 31' Excella II
New Market , Alabama
Put some lock tight on the threads.
Perry
Old 10-03-2015, 11:40 PM   #14
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
Adding my voice to this. I can trigger a hinge release by pulling a blanket out of the closet shelf (2015 International). They are very easy to release. The same thing happened on my 2004, but those hinges were easy to pop back. These are impossible -- I'm completely stumped on putting it back. And I have euro hinges in my home, so I thought I was familiar with them.
Am I seriously going to have to buy and carry a rubber mallet with me, or is there a trick to this that I'm missing?
lbdesign is offline   Reply With Quote
Where can I get cabinet/door hinges? Hummer Cabinets, Counter Tops & Furnishings 18 10-07-2014 08:36 AM
80 airstream cabinet hinges bluegoat80 Cabinets, Counter Tops & Furnishings 3 01-29-2010 10:39 AM
New cabinet doors and hinges seventythree Cabinets, Counter Tops & Furnishings 12 12-17-2009 10:05 AM
80 airstream cabinet hinges bluegoat80 Cabinets, Counter Tops & Furnishings 5 12-02-2009 07:25 AM
replacing CABINET/storage door hinges. bookman Cabinets, Counter Tops & Furnishings 5 08-04-2008 11:23 AM
