Old 02-04-2010, 02:04 PM   #1
Freeheel's Avatar
2009 19' International
Calgary , Alberta
Images: 13
Electrostatic Corrosion Control System on AS?
Hey Gang
I came across this device shopping online at Canadian Tire and thought it was kindof interesting:
The manufacturer claims: "The CounterAct electrostatic corrosion control system was specifically designed to address open air corrosion problems. CounterAct's technology, because it relies upon electrostatic fields rather than impressed current electricity, is currently the only proven and demonstrated electronic method that can effectively deal with the problem of open air corrosion."
Elsewhere they state:"A modified version of our proven OR-4 design modified to specifically address the corrosion problems of aluminum body steel frame vehicles. especially suited to addressing galvanic sell corrosion at frame/body junctions"
I'm wondering if anyone has installed (or thought about installing) one of these units on their trailer yet to counteract filiform corrosion? Seems like it could be a possible solution ...assuming it works in this particular application.
See www.counteractrust.com/ for more info.
PS: Apologies, in advance, if the ground has been covered before. I did do a search but came up blank. ...unless you count the 72 page "corrosion" thread which I don't have a week to read through
Freeheel is offline   Reply With Quote
Old 02-04-2010, 02:55 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I didn't find much on their web site. Not even an estimated price. You have to fill out a form to request a quote.
I'm thinking snake oil.
Old 02-04-2010, 02:56 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Old 02-04-2010, 03:01 PM   #4
Wayne&Sam's Avatar
Images: 21
I found a price. The model used for Gummer/Land Rover is "optimized for aluminum body/steel frames. $550.
Jammer was to the point. Three times.
Old 02-04-2010, 03:02 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Sorry, trouble with getting the image the way I wanted it. They don't show up in the preview.
Old 02-04-2010, 03:13 PM   #6
RBolton's Avatar
Belington , West Virginia
I have not used this product, but here is a story anyway.
I own a car dealership in WV and about eight years ago two brothers moved here from Ohio. They had just recently retired and were originally from here. They both traded in 5 or 6 year old trucks at my store.
One truck showed the usual amount of rust and corrosion for the region. The other truck had a corrosion control device installed. I remember the brand name was something like Rust Evader.
The truck with the Rust Evader device had almost no rust or corrosion on the body, frame or bumpers. However, anything that was isolated from the body and the frame was rusted way worse than one would expect given the age of the truck. I am talking about brake tubes and fuel lines, exhaust manifolds, spark plugs, shocks, egr plumbing, etc.
It appeared that the electronic corrosion control worked but that the parts that did not get the charge from the Rust Evader had to do all the "reacting" with the corrosive elements that normally would have been spread across the entire truck. Instead of everything being corroded a little, these parts were rusted a lot.
Observing this made me think that these systems do work. As far as combating filiform corrosion - I don't know. Just thought I would let you know what I saw first hand.
Roger
RBolton is offline   Reply With Quote
Old 02-04-2010, 03:28 PM   #7
RBolton's Avatar
On the other hand, see this.
http://www.ftc.gov/opa/1996/07/rust3.shtm
Old 02-04-2010, 03:54 PM   #8
Wayne&Sam's Avatar
Images: 21
I love it when I'm right. It happens so infrequently.
Old 02-04-2010, 03:56 PM   #9
Freeheel's Avatar
Calgary , Alberta
Images: 13
Interesting. It could be snakeoil, but my company is a supplier to Canadian Tire also, and I know that they are pretty rigorous with their product evaluation before they decide to list something. They have a whole department devoted to product testing, in fact.
CounterAct Electronic Rust Protection System | Canadian Tire
Interesting to read the customer reviews. Some say it works, some say not.
Old 02-05-2010, 04:09 AM   #10
Wayne&Sam's Avatar
Images: 21
I think it may be one of those things that works in theory, but in the practical appilacation, not so much.
Old 02-05-2010, 04:56 AM   #11
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I was the materials engineer for Outboard Marine Corporation (Johnson/Evinrude outboards) I was asked to evaluate cathodic corrosion protection vs active electronic protection for our aluminum/steel outboard motors and stern drives. If a unit is completely submerged in a conductive liquid (salt water) both systems will cause a field and current to be generated which protects the least active metal on the galvanic series to be protected. In our case we used a zinc anode which protected both the aluminum and the steel. It did not protect the zinc plated steel parts. The zinc plate did protect the steel that might be exposed where the zinc plate had been scratched off the steel part. As long as the battery lasted the electronic system worked just as well.
An Airstream is not the same thing. It is not submerged in a conductive liquid (unless you are continuously spraying it with salt water. For the bottom of the unit which you may frequently drive in states that use salt to coat the roads, an electronic system or cathodic protection might be of benefit. I would encourage all those people to make sure the bottom surfaces where the salt may accumulate to be careful that they do not have dissimilar metals in contact unless you want the more highly reactive metals to sacrificially corrode to protect the rest of the metals. The zinc plating (galvanized) will likely be the first to go. If you observe rust on any zinc plated steel parts replace the parts immediately as the zinc plate has exhausted itself. I do not think the type of device, that is the subject of this thread, will do you much good on an Airstream travel trailer..
Old 02-05-2010, 06:41 AM   #12
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Back in the day we installed a similar product on the inside fender-well of our Volvo 240 parts delivery wagon. By the third Bflo. Winter it was hanging by the wires below a very precise rust hole, I guess it worked too well!
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-05-2010, 08:08 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What works in theory and testing all too often does not work in the real world.
I think that gizmo is the electronic equivalent of the bumper-mounted deer warning whistles of a decade or so ago.
Old 02-05-2010, 09:55 AM   #14
_
Originally Posted by Freeheel View Post
...is currently the only proven and demonstrated electronic method that can effectively deal with the problem of open air corrosion."
as i understand it...
1. filiform isn't 'open air corrosion',
-in fact ONE of the techniques used to deal with filiform is to scrape the clearcoat OFF and open up the worm track...
2. 'aluminum body/steel' frame contact isn't the issue on a stream, the filiform isn't galvanic/2 metal corrosion
3. YOUR 'stream has a rubber/butyl tape LAYER between the outer skin/shell and ribbing/inner skin, which is ALL aluminum.
4. the tape isn't a perfect insulator, but 'conduction' through-out the entire metal vessel isn't SIMPLE or direct...
5. the trim pieces (door handles/hinges/tail lights) almost ALL have gaskets from the shell (although the rivets/screws penetrate to metal)
6. and some of those trim pieces that will develop 'open air' corrosion aren't alum or steel alloys (they are 'bright work plastics or 'pot metal' type mixes...)
...count the 72 page "corrosion" thread which I don't have a week to read through
no offense but...
FIND a week OR 2 and read that thread and links and ABSORB what other members have taken the TIME to post...
there IS useful stuff there related to YOUR trailer and the potential issues/solutions.
and much of the good stuff is in the first 100/200 posts which won't take a week to read.
does having another multipage page thread just to promote a USELESS item or answer basic questions AGAIN...
serve a purpose?
think of ONE LONG thread as a "proven method...specifically designed "
4 dealing with and CONNECTING all the thoughts on one specific issue...
without CORROSION of the topic by
mixing DISSIMILAR mental notions, incomplete connections or promoting useless gadgets...
cheers
2air'
Corrosion offleash Ribs, Skins & Rivets 5 01-04-2008 08:07 PM
ECO Cruise Speed Control System Paul Dobbin Land Yacht/Legacy Motorhomes 4 11-12-2006 01:38 PM
Corrosion Zugbug Ribs, Skins & Rivets 7 07-06-2006 05:16 PM
Need help with corrosion SAMCPA Ribs, Skins & Rivets 8 04-28-2006 09:14 PM
