Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-01-2004, 09:06 AM   #1
bradandamanda
bradandamanda's Avatar
Profile:  Gadsden
Electrical and Water
Help! We are new to camping and not as mechanically inclined as some. Two questions:
1.) Electrical - It seems that someone has rewired the camper with home wiring. The plug from the main power source has been cut. There are wires from the rear access panel that the previous owner supposedly straight wired into. The battery source will power all lights, but we do not understand how to find out if we are running on 110 when we plug up or if we are using only battery power.
2.) Water Leak-
When we plug up the water supply, there is a lot of water dripping from various areas in the rear. No water will come through the faucets. Is there some type of pump system that should be activated, and what is leaking?
Thanks in advance for any basic Airstream 101 advice.
Brad and Amanda
bradandamanda is offline   Reply With Quote
Old 05-01-2004, 09:44 AM   #2
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
manual
Starting with the water, if you have your manual check to see the winterizing instructions it gives. You may be lucky and the previous owner opened the drain valves to prevent freeze. Don't forget the drain valve on the water heater as well. Find them, close them and try filling again. You should be able to see the water draining if the valves are going, if the leak is difficult to find you may have a loose fitting or burst pipe and will have to backtrack it to find and ix. If you don't have a manual search this site and you'll see threads on how to find one. For the electrical, my lights run off of the battery even when plugged into power. My electrical outlets however only operate when plugged into 120. Try plugging the trailer into power and test your outlets. Welcome to vintage airstreaming....
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Looking For Water Heater GT1963 Water Heaters, Filters & Pumps 22 07-10-2004 01:42 PM
Water Leaks and Condensation-34' LTD lmcatee Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-04-2004 04:16 PM
Water Heater HELP!!! srae Water Heaters, Filters & Pumps 3 09-03-2003 04:53 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
