Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 01-04-2020, 10:56 AM   #1
2017 23' Flying Cloud
Leroy , West Virginia
Electrical problems
I’m not sure what’s going on on my 23 foot flying cloud.
Here’s the issue the fans are not working as well as the furnace and overhead lights.
I’ve checked the breaker it seems to be working the small fuse on the number 2 circuit and light does not come on when you pull the fuse out.
Any clues?
A234927756 is offline   Reply With Quote
Old 01-04-2020, 11:40 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
Do you have a multi-meter?
Pull the fuse. Using the ohms scale check the fuse. It can look good, but be bad.
While the fuse is out. Use the DC voltage scale and measure the voltage at both sides of the fuse socket.
Anything?
-Dennis
batman is offline   Reply With Quote
Old 01-04-2020, 11:46 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Do any other 12V devices work? If so which ones?
Are you on shore power? If so, do 120V devices work in the trailer?
If all 12V is out, when was the last time it worked?
What position is the use/store switch in?
Lots of fiddly details and directions this could go ......
Old 01-04-2020, 12:13 PM   #4
2020 23' Flying Cloud
2019 22' Sport
Sebastian , Florida
I had a similar problem in my '19 22FB Sport. Front interior lights and Fantastic fan, on #1 DC fuse, would not run. (Fuse would blow immediately as confirmed by the indicator light). I got a wiring diagram from J-C and took it to a local shop, who found that a Fantastic mounting screw had skewered a wire to the fan.
I'm usually "capable" on these things, but this problem was tricky. Talk to J-C and get the help you need.
GetawA-S is offline   Reply With Quote
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjzuk General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
Electrical Problems Bob Baker Electrical - Systems, Generators, Batteries & Solar 4 06-20-2003 11:31 PM
Electrical problems... DbackFan Electrical - Systems, Generators, Batteries & Solar 9 02-13-2003 10:44 PM
