Old 10-01-2016, 04:41 PM   #15
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Last winter my brother in-law bought a Lasko ceramic tower heater. It has a digital display, a remote control. It rotates so that it heats evenly.
When the heater I presently have dies, I most likely will get a Lasko. I was really impressed by the evenness of the heat.
A W Warn is online now   Reply With Quote
Old 10-01-2016, 06:33 PM   #16
2010 25' FB Flying Cloud
Davenport , Iowa
I , too, have a Dyson and it does a great job. The heater and fan are adjustable. It has a remote, so don't have to get up. The fan does a good job in the summer. Bought as a reconditioned with full warranty.
Airtandem is offline   Reply With Quote
Old 10-01-2016, 09:47 PM   #17
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
we use a small oscillating heater with adjustable settings ...I think 750-1500w... but my favourite addition last fall was an electric blanket on the bed with dual controls .... we mostly have just used it to have a toasty bed to climb into but its a great option if you wake up a little cold during the night.
rucos is offline   Reply With Quote
Old 10-03-2016, 06:35 AM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I also use one of the heaters that looks like an old radiator.
No danger of catching anything on fire.
The cat (RIP) loved it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 10-03-2016, 07:14 AM   #19
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Our milk house heater is $17. right now at Rural King. Walmart carries them in some places.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 10-03-2016, 02:18 PM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by LY007 View Post
I've looked at a lot of nice ceramic space heaters to use in the fall and spring until I get around to replacing the propane furnace.
My only hesitation is that most of them seem to be 1500 watts, which is kind of pushing it for a 15 amp circuit.
What are you guys using successfully?
Hi Steve
I use a permanently installed pic-a-watt electric heater. They can be jumpered for various wattages when installed, anywhere from 400-1500 if I recall correctly. I have mine set for 1500.
Electric heat is a fruitful source of RV fires, and there have also been some tragic accidents where people used a generator to run their electric heat overnight leading to CO from the generator accumulating in the RV. Don't let that be you
For fire safety I believe the safest thing to do is find a place where you can permanently mount an electric heater where proper clearances to everything are maintained. Bedding is the usual problem particularly since so many areas can be made up into a bed.
I have some photos of my install that you can search for if interested.
I find that with my 30' the 1500 watt heater will keep the trailer about 15 degrees warmer than it is outside.
Electric trailer dolly recommendation J Goertzen 2002 - 2005 International 38 06-29-2016 08:33 AM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Can the circuitry handle an electric space heater wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 15 03-30-2007 08:05 PM
Electric Space Heater Pecos Pete Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-02-2007 11:09 AM
Electric Space Heater Recommendaton flyfisher General Interior Topics 15 03-04-2006 07:02 AM
