Old 12-11-2014, 07:41 AM   #1
dougandlori's Avatar
2004 28' Classic
Fresno , California
Electric heater thoughts
Next month I will be in Williams Arizona for 5 nights. Elevation 6700 feet so very cold in January. Two of those night will actually be in the Grand Canyon and the Airstream in Williams empty. I was thinking about a small portable electric heater running while I was gone to keep it from freezing. I thought that may be more efficient than using the propane heater. Any thoughts or suggestions? Thanks
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 12-11-2014, 07:55 AM   #2
dznf0g's Avatar
Oswego , Illinois
Electric works fine....for the lines and fixtures ABOVE the floor. The tanks and dump valves will not be protected without the propane furnace pumping warm air to the pans.
Here is a longer term fix for you, works well:
http://www.airforums.com/forums/f427...ase-74624.html
-Rich-
Old 12-11-2014, 07:58 AM   #3
Lily&Me's Avatar
Normal , Illinois
I agree with Rich,
We were in that area in one of the early years of Interstate ownership, Doug at Gunsite, and woke one morning to 18 degrees or so.
Our pipes had not frozen, but the outside water hookup did.
I would leave your furnace running at a modest temperature, and cabinet doors open, just to be safe.
Maggie
Lily&Me is online now   Reply With Quote
Old 12-11-2014, 08:09 AM   #4
mandolindave's Avatar
there is a post on the forum about winter at the canyon
When I winter camp, I drain and winterize. I use containers of water, a portipotti, and an oil filled electric radiator as backup. Is there somewhere with a shower you could use.
I was using a small electric heater a few weeks ago. The camper didn't get very warm, and the heater crapped out, perhaps it was overworked. The small heater worked well in 50 degree weather to take the chill out
mandolindave is offline   Reply With Quote
Old 12-11-2014, 08:27 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, In really cold weather, I only use my furnace to protect my tanks. During the day, if not freezing cold, you could use an oil filled heater. The heat from the oil filled heater will warm up the thermostat, not allowing the furnace to work.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-11-2014, 08:40 AM   #6
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
Dyson Heater AM05
Amazon.com - Dyson AM05 Hot + Cool Fan Heater, Blue - Electric Household Fans
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
Gas-Electric HW Heater oldvws Water Heaters, Filters & Pumps 6 11-01-2011 03:04 PM
Bowen Water Heater Rebuild, thoughts? Jim & Susan Water Heaters, Filters & Pumps 19 10-21-2009 10:48 AM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
