Old 08-20-2012, 10:13 AM   #1
1999 28' Excella
1992 35' Airstream 350
Northfield , Minnesota
Electric Dump Valves
I have a 1999 28Foot excella and am considering installing electric dump valves on the black and grey water tanks.
I have back problems and opening/closing the valves is an issue for me.
I am looking at the Barker Auto drain since there are no installation positioning issues with them as there are with some others.
Does anyone have any experience with them ?
Thanks..
J R Vaughan is offline   Reply With Quote
Old 08-20-2012, 10:23 AM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Jim,
I'm checking in with the same question. Ours is same year, 30'
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-20-2012, 10:31 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Jim,
Well, I'm no help on the dump valves.
I do complement you on being able to spell "Vaughan" correctly.
Vaughan
Old 08-20-2012, 10:36 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Airstream Interstates come from Jackson Center with electric dump valves and macerator pumps. Discharge line from the tank to the pump is still your standard 3-inch line, but the pump discharges through a smaller line (3/4-inch, if memory serves).
I don't know who actually makes the electric dump valves that are installed on the Interstate, but you can't beat them for convenience. The first couple of times I used the electric dump valves, I didn't hold the switch long enough for the valve to open fully; the valve opens slowly. Once I figured that out, I had no trouble ever since. Switches are lighted so you can tell if the valve is open or closed (light on=open, light off=closed).
Only problem you might have is that no matter how conveniently you place the electric dump valve switches, the discharge hose is still down where it's awkward for people with old backs like yours— or old knees like mine— to reach.
I solve that problem by carrying a small folding stool. At the dump station, first I set up the stool, then I sit on it to unreel the hose and operate the dump valve switches.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
