Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 10-20-2012, 10:14 PM   #1
1977 31' Sovereign
jasper , Missouri
Electric brake kits
Need to change old hydraulic brakes for electric. Can I get a kit for old axles or do I need to get new axles?
ssburkhalter is offline   Reply With Quote
Old 10-20-2012, 10:37 PM   #2
You amy need to replace the axles that are that old. The following article will help you check them out.
The Dura-Torque Axle
Replacing disc brakes with electric brakes, is really taking a step or two backwards.
Some parts are still available for the original Excellavac disc brakes.
But, should you still decide to replace the disc brakes with electric brakes, you should consider the self adjusting electric brakes.
They cost a little more, but the issue of having them adjusted every few thousands of miles, will be long gone.
Andy Rogozinski
Inland RV Center
Corona, CA
