Old 08-20-2017, 12:17 AM   #1
1974 Argosy 24
lake dallas , Texas
Electric brake assembly
I am somewhat new to the Airstream world. I have a 74 Argosy 24 that I am restoring, but right now I am stuck. I know the camper has an electric braking system, but the assemblies need to be replaced, what size assembly is the original? Would like to get the parts order before I start ripping off tires to change everything out. TIA.
Terrie is offline   Reply With Quote
Old 08-20-2017, 06:11 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forum.
Argosy trailers could have either 10" or 12" brakes. Both are readily available, but you will need to determine which size you have. If they are original, it would be a good idea to replace the drums, bearings, and seals. And while you're sitting there looking at them, you would do well to replace the shocks, if they are originals.
By the time you buy the brake assemblies, drums, bearings, and seals, you are most of the way to the price of replacement axles, so that might be a good idea. They should come with all those parts, except the shocks.
Old 08-20-2017, 07:56 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
X2 on axle replacement unless a PO did it.
10" brakes have 4 bolts in the back plates
12" brakes have 5 bolts in the back plates.
Old 08-21-2017, 10:24 PM   #4
1974 Argosy 24
lake dallas , Texas
thanks for the advice, I think I am going to go ahead and replace the entire axle assembly, looks to be cheaper that way, plus I don't have to worry with replacing anything else down the road for a while
Older Airstream hydraulic brake to electric brake conversion fastinjun71 Brakes & Brake Controllers 1 06-09-2016 03:46 PM
1992 brake assembly firedog 1990 - 1993 Excella 3 01-25-2009 12:16 PM
Brake Buddy and Tow bar assembly smily Tow Vehicles 0 03-28-2007 07:01 AM
Disk Brake Assembly Balancing JimGolden Brakes & Brake Controllers 14 11-29-2005 01:50 PM
Brake light assembly replacement Stinky Lights - Interior & Exterior 0 10-27-2003 05:59 PM
